Quich question about 07 Front End Conversion
I'm planning on converting my 2001 7.3 4x4 to a Harley Davidson one...as close as I can. I am looking to start with the front end and found this conversion kit.http://www.mkmcustoms.com/fordfull07...paintable.aspx. Does anyone have any experience with using this company and if so how was the fit and finish of their product? I understand the best way to go is using genuine Ford parts but I was curious what you all thought about using this kit?
I would do a CL/eBay/junk yard search and see what you can find. more often then not you can source everything you would need for cheaper and closer without having to put out 1500$ plus paint and shipping.
That being said, i have seen they're conversion lights in person, the ones that fit the 99-04 header panel and they fit perfect, as well as the grille that was almost perfect. These pieces probably would not fall under that category because this is a full swap and you would be replacing all the components completely
Justin
Justin
I just bought this: Ford Paintable 05-07 Super Duty/Excursion Grille Fits 99-04
this, Ford 99-04 Black One Piece Headlight Pair Fits Super Duty/Excursion
and these, Red LED Tail Lights For 00-04 Excursion
I will let you know when they arrive next Monday.
I bought Sinister Diesel's aftermarket Harley Grille, since it was about 1/5th of the cost of a new one. I am happy with it, but still prefer an OEM, though they are getting harder to find.
This was my 00 XLT right after getting it home.
This is right after I hung the new 05 Header panel, OEM Ford Harley Headlights, and I used Riff-Raff Diesel's adapter plugs to plug the 00 harnes to the 05 lights. The grill is the MKM Grill, and the bumper is a 2005 Excursion bumper, so fits perfect with the new grill.
And this was after the new springs, and the tires and rims off my F350...
And THis is it as of today!
Hopefully this helps! I personally would recommend replacing the header panel. It was only $110 and makes the mounting of the lights and grill all factory. This is the second Ex that I have done the Harley treatment to...
This was my first!
Garry, Kodiak, Alaska
This was my first!
This was my first!
This was my first!
This way I get an '05-'07 Limited Excursion with a 7.3.
So when I ran across a 2000 XLT Ex that had only 70k miles, had a V10 with a Whipple supercharger and Banks headers and exhaust with factory 4.30 gears, I made a quick trip to Anchorage, bought it for $8,500 and then flew home to arrange ferry tickets to get it home. In the meanwhile, cleaned out the 05, removed my Road armor bumper and a few other items, and reinstalled the original bumper, and sold it about a month later with only 46k miles. Then started ordering parts to make the 00 like my old 05... Still working on the 00, but slowly getting it to where I would like it to be, and have already put over 5000 miles on it here on the island in 11 months...
Good luck with your, and if you have any questions, just send me a pm etc.
Garry,
Kodiak, Alaska
How it fits...
The replacements are a tight fit because it is all one piece rather than the OEM two piece set up.
They look like the Harley system with a row of LED's, all I have to do is run a wire and switch for DRL to the LED. I want to use DRL when I want, not when the Nanny state tells me to have them on.
The tail lights will be in Monday and I will post a complete how-to when I am finished.
LED tail lights
Installed the LED tail lights. Fantastic
Not happy with the production of light from headlights so I am getting HID and LED fog lights.
Low beam is ok not great, high beam is not very high ^ and not very much.
When the HID arrives I will then hook up the LED strip as DRL's.
Love the look but it is more important to have actual light.
To be continued.
To be continued.
