If I change the dash lights power window and lock switch lights headlight 4wd switch lights to blue LEDs will they show up blue or is there a green film over the dash? I'm tired of the green not matching my aftermarket gauges and radio. 2003 f250 crew 4x4 6.0. Auto
some years have a green film on the back of the gauges, you would need to pull the dash out and see what color the bulbs are, if they're clear you would need to remove the film and put in blue LEDs to achieve what you're looking for. I did this on my old explorer
As far s the door switches those i never did but believe those are a little more involved.
The 4wd switch will require you to remove the old bulb and solder in a blue LED to the pedestal for it to work, same with the headlight switch.
