Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
gearing
Old Nov 19, 2013 | 06:02 AM
thesixd's Avatar
thesixd
gearing
I'm working on making my '75 c600 rescue fire truck a better daily driver. I figure on this site people won't laugh at me like they do in the general public. You'll need to give me a break on the technical stuff because I'm a carpenter and not a mechanic. Truck has a 360/361 with a 4 speed Allison automatic. The Rockwell rearend has a 0720 gear ratio. No tach in truck, but its screaming at 50 mph. The other issue is that the truck struggles to get up a good hill. Motor is cleaned up and running fairly well, still needs fine tuning. GVW is 21,200 lbs, but full of tools it runs at 15,500 lbs. I may tow a small trailer from time to time, but that will be consistant weight for the most part. I'm considering a different gear ratio ie. 583 or 529. what will this mess up ?
Old Nov 21, 2013 | 09:18 AM
dmanlyr's Avatar
dmanlyr
You really need more than 4 gears. Do you have the lighter duty AT540 that was installed in some of these trucks was intended as a city transmission only. It does not have a wide enough gear spread to do everything properly
You really need a 5 or 6 speed Allison. If not that, then a two speed rear end is a work around.
Taller rear gears raise all the effective gear ratios in the tranny. You may find that first gear is now not low enough if you live in hilly territory.
Just my thoughts.
David
Xenthrax
16
Apr 26, 2012 09:33 PM
mbarrad
13
Feb 23, 2012 04:36 PM
polacko
32
Jun 14, 2010 08:00 AM
Tumblindyce
34
May 23, 2010 09:56 AM
BlueOvalBud
51
Jun 21, 2009 08:36 PM
