Modular V10 (6.8l)
LOW ON OIL
Old Nov 17, 2013 | 12:28 PM
handifletch's Avatar
handifletch
LOW ON OIL
I hate to admit it but was so busy I took my truck to a Conoco express for an oil change and the morons did not tighten the drain plug and I lost about a quart and a half of oil on the v10. Noticed the oil pressure did not come up immediatly on start up but showed full pressure after about 30 seconds. I found the problem and resolved. Should I be worried if it ran this way for about 60 miles? Most of the feed back is that with the synthetic blend it should be ok. Input would be appreciated.
Old Nov 17, 2013 | 06:33 PM
scraprat's Avatar
scraprat
Top Answer: 5
If you only lost a quart or so you should be ok.
Old Nov 18, 2013 | 06:56 AM
JWA's Avatar
JWA
Maybe contact that outfit, talk to a regional supervisor and let them know what happened. In the event of any damage you'd want to have this mishap on record. Keep the receipt too!
Since you caught this soon enough its not likely any damage has been done. Good catch on this though.
Old Nov 18, 2013 | 05:02 PM
jesse5's Avatar
jesse5
No problem whatsoever.
Old Nov 18, 2013 | 08:35 PM
handifletch
I documented everything and wrote a couple of letters as backup. I am pretty confident after all of the response that all is ok. thanks for the feedback.
improvement54
15
Dec 30, 2022 02:41 PM
superdentf350
Nov 15, 2018 12:00 PM
Schooner 45
Nov 17, 2008 07:15 AM
MPHorvat
Jan 28, 2008 03:10 PM
amw_drizz
1978 - 1996 Big Bronco
22
Mar 14, 2005 05:16 PM
