Rear Bumper Brackets
Old Nov 16, 2013 | 08:22 PM
smallello's Avatar
smallello
Are we there yet?
I have a 56 F100 and would like to move the rear bumper up and in. I already did the front and want to do that rear now. I know I can buy new brackets but I want to see if I can modify the existing brackets.
Before I go through calculating it, does anyone know where to cut and re-weld? Has anyone done this or is there a standard for doing it?
Old Nov 16, 2013 | 10:50 PM
CharlieLed's Avatar
CharlieLed
The process is relatively simple, take a piece of flat stock and place it across the backside of the bumper and drill the holes to mount the bumper. Take another piece of flat stock and bolt it to the frame in the stock mounting holes. Weld the two together...no need to mod the stock brackets. Here is a pic of what the bumper looks like after the mod...
Old Nov 17, 2013 | 09:57 AM
smallello's Avatar
smallello
Are we there yet?
No need for a curve in the bracket off the frame? It seems it would be a little too high.
Does the top of the bumper sit even or above the body?
Old Nov 17, 2013 | 10:30 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Why not just drill new holes in the frame?
I can't speak for the '56, but the '53 has a second set of holes that raise the bumper to be even with the bottom of the rear bed crossmember.
Here are some pix of my truck pre-fitting the bumper in the upper holes. If I remember correctly (I have it written down in my build notes but don't have them with me) the bumper will be around 3" from the bed in these holes. If you want it closer drill more holes. Just don't turn your frame into Swiss cheese.
PS: I love the bumper on the black truck. That's what I was planning to build, except I'm going to shave the bolts and put the tail lights in it.
Old Nov 17, 2013 | 11:00 AM
CharlieLed's Avatar
CharlieLed
Both the blue and the black truck have the same style bumper mounts. As for where it sits...that's entirely up to you and how you choose to fabricate your mounts.
Old Nov 17, 2013 | 11:59 AM
smallello's Avatar
smallello
Are we there yet?
I was hoping someone might weigh in that has cut theirs. If not maybe I will do it and post how it goes...
Old Nov 17, 2013 | 05:10 PM
WALFORD'S 56's Avatar
WALFORD'S 56
I have a set of snugger brackets left over from a 56 build.
Old Nov 17, 2013 | 06:49 PM
Moe Craig's Avatar
Moe Craig
I sent ya a PM
Old Nov 18, 2013 | 05:39 AM
raerjim's Avatar
raerjim
Remove about 2" from the downward angle of the bumper mount and reweld. I did about 1.5" and wished I had done 2". This pic is before raising the bumper. I was looking at having no good spot to relocate my tag to So my removing 1.5" was a good compromise. I'm trying to find decent pic post-raising. Stand by.
Old Nov 30, 2013 | 12:44 AM
smallello's Avatar
smallello
Are we there yet?
So I cut a 2" chunk out of the brackets and welded them back together to move the bumper up and in.
I left the original one on to show the difference. You can see the right side is 2" higher and 3" closer.
Old Nov 30, 2013 | 12:52 AM
smallello's Avatar
smallello
Are we there yet?
I would like to mount my license plate to the bumper but I don't want to drill holes in it. I am looking for a bracket that will work without holes...
I see this mounts to a tube style bumper. Anyone know there is something like this for a square bumper?
Old Nov 30, 2013 | 02:15 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
If you can cut and weld you can fab one real easy.
Old Nov 30, 2013 | 10:28 PM
smallello's Avatar
smallello
Are we there yet?
Yeah, I will fab something very simple to clamp the plate to the bumper.
Brackets finished and bumper back on.
Old Dec 1, 2013 | 01:42 AM
EffieTrucker
Looking good!
Old Dec 1, 2013 | 06:08 AM
raerjim's Avatar
raerjim
Just right.
