54 truck engine question
Old Nov 16, 2013 | 05:46 PM
nabengt's Avatar
nabengt
Found what appears to be a remarkably solid and original 54 f100 for a fair price. Has a 239 engine that blew a head gasket supposedly in the 80s and been sitting since. Locked up.
My intentions with this truck would be to restore as original as is practical. Get it in solid driving shape first. Body looks cool as is until I'm ready for that. I want to stay period correct but I'm not hung up on the finer details. Want something that is fun and reliable to drive around a bit. I gather that a 239 is a bearcat to rebuild. And there is no such thing as "matching numbers" for these trucks.
Should I try to: Find a running 239 from the same year? Would there be some kind of casting number I should try to match if possible?
Find a later 292 or other such Y block? And if so, Would it drop in and bolt right up to the existing transmission?
Old Nov 18, 2013 | 01:23 AM
jonnireb's Avatar
jonnireb
The 239 isn't any more difficult to rebuild than any other engine, but parts availability
may be a problem. Yeah a 292 will bolt right in, I have a '55 with a 292replacing it's original 239.
Old Nov 18, 2013 | 03:03 AM
1958 Ford F250's Avatar
1958 Ford F250
Smile 54 F100
Hi, I have a 1958 Ford F250 and it has a 292 Y BLOCK 4.8L and all I can say it was in rough shape and it has been Fairly easy to Find-Replace parts and rather easy to work on and I'm not a Mechanic but I know a little bit. If you decide on a 292 mine RUNS STRONG and SMOOTH of course after you tune it up and again nothing to it, simple to understand and work on. If you pull your 239 out you should be able to drop the 292 in and bolt right in. GOOD LUCK !!!
Old Nov 18, 2013 | 07:18 PM
The Horvaths's Avatar
The Horvaths
"Bolt right in" depends upon the origin of the "new" engine. Worst case, you may need to use the old timing cover for truck mounting. If so, you'll likely want to go with the original water pump and high-mount fan. Exhaust should be upgraded to dual. The 239 exhaust may not line up just right anyway. But, as changes go, it is not bad at all.
Old Nov 18, 2013 | 08:16 PM
charliemccraney's Avatar
charliemccraney
The answer depends on what you call practical. A 239 will be more expensive to rebuild and parts are harder to find.
A 292 will be cheaper and make a fine substitute but anyone who knows those trucks will know right away that it is not the 239 so the originality will be out the door.
It is true that there is no such thing as numbers matching, but there are date codes. If you intend to restore this as original, and possibly sell it one day as original, the date codes on the parts will need to jive with the production date of the truck. Even then, if it's not the original engine, it is in no way, shape or form "original" in my book.
Old Nov 19, 2013 | 08:48 AM
nabengt's Avatar
nabengt
Good counsel.
I would in no way try to pass the engine off as original if it wasn't. Didn't mean to imply that. Just looking for a cost effective way to get it on the road and stay somewhat period correct.
Got a rough idea what a 239 rebuild would cost?
Old Nov 19, 2013 | 09:12 AM
charliemccraney
I don't know what it will cost. Check the usual old Ford places. To do the average Y block right will cost about $2500. It will vary from region to region, and there may be corners you can cut to shave a bit off without sacrificing the quality too much but that's a good ballpark cost. Machining costs should be the same for a 239 but I'd guess that parts could kick it up another $500 to $1000.
It sounds like you will be happier with a 292 in the long run. Get a '57 or newer 292 and go from there. You'll have more power, more easily sourced replacement parts, more common maintenance items.
Old Nov 19, 2013 | 08:06 PM
The Horvaths
This is in the a Dallas, TX area:
292 y-block and 3-speed transmission
Old Nov 23, 2013 | 11:13 AM
nabengt's Avatar
nabengt
Spoke with someone who said you can rebuild a 239 as a 272 with a larger bore and 272/292 crank. Anyone seen that done? What other considerations?
That would be a cool way to keep the original block but get some more power and perhaps cheaper parts.
Old Nov 23, 2013 | 12:59 PM
pintoplumber's Avatar
pintoplumber
I've done it, don't know if it's worthwhile. 239 + .125 and I had a 312 crank turned down to 292 mains. Gives me 283". I probably spent $7200 on the motor over the years. It would be cheaper to fix up a 292. To use bigger heads on the 239 block you have to drill water passages in the block at #4 and #8. You probably won't find a cam for your 239. Dennis
Old Dec 27, 2013 | 03:31 PM
orange1954's Avatar
orange1954
Trailering
I have a 239 Y block that I pulled from my truck ~15 years ago. It ran when I pulled it. Complete engine (carb, starter, etc,). Looking to clean the barn so would sell it quite cheap.
Old Dec 29, 2013 | 10:39 AM
Y-Blockhead's Avatar
Y-Blockhead
It ran when I pulled/parked it. Oh, how many times I've heard THAT ONE...
Old Jan 7, 2014 | 07:54 AM
Bessie's Avatar
Bessie
I've had many 239s over the years and have really not had troubles getting parts for a rebuild. It does take a little extra time to round up the parts, but you will find them. I recently moved and gave away two 239 blocks and several parts. Hang in there and be patient!! Make the decision to stay with the original block - stop thinking about it and get it done!! Yes, I am a purist for an original stock truck. If your not, take the easy route and find a 292.
nabengt
Nov 16, 2013 04:39 PM
250Cowboy
Jul 22, 2012 09:51 PM
a BigR HamR
16
Jul 10, 2008 11:28 PM
54 Ranchwagon Guy
13
Jan 20, 2008 01:58 PM
55and65effies
13
Jul 22, 2006 08:08 PM
