35s help mpg?
Old Nov 14, 2013 | 08:16 PM
Baja7.3's Avatar
Baja7.3
35s help mpg?
I got a 89 7.3 with c6 3 speed tranny, I get ****ty mileage and at 45mph I'm at 2k rpms I got a set of 35x12.5. Do u think if I put those on it will stretch my gears out more helping mpgs at all?
Old Nov 14, 2013 | 08:23 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
lol no.lifting a truck hurts economy,as does adding 12.5 wide rubber.an OD trans swap is the only real way to gain economy from the old school c6 trans.sounds like you have 4.10 gears too which doesn't help.swapping a 3.55 rear will help a bit.not like adding an od trans of course but something.
Old Nov 14, 2013 | 08:27 PM
Baja7.3's Avatar
Baja7.3
U think 35s will hurt mpg to much since I obviously have higher gears. Lol I want 35s anyway
Old Nov 14, 2013 | 08:45 PM
Evan_P's Avatar
Evan_P
Bigger tires kill MPG. End of story. I had 35's and HATED them in every way. I have 33's now and they are still on the big side. But they don't make the Duratracs in 31's or 32's so 33's are my only choice.
Old Nov 14, 2013 | 09:53 PM
Encho's Avatar
Encho
The Southernmost Mod
They do make the Duratracs in 31x10.5 size, I researched this when I bought my tires because I considered importing them. Amazon carried them.
See?:
Amazon.com: Goodyear Wrangler DuraTrac Radial Tire - 31/1050R15 109Q: Automotive Amazon.com: Goodyear Wrangler DuraTrac Radial Tire - 31/1050R15 109Q: Automotive
Old Nov 14, 2013 | 10:06 PM
Evan_P's Avatar
Evan_P
See?: Amazon.com: Goodyear Wrangler DuraTrac Radial Tire - 31/1050R15 109Q: Automotive
Well I'll be darned. They were not available to my dealer when I ordered my tires. Will keep that in mind when I get my next set of tires. Of course that isn't for a while...
Old Nov 15, 2013 | 07:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
7.3 with 4.10 gears C6 trans and 35X12.5X16.5 radials should give you around 14 mpg.
the 35's will raise mpg on the highway, but lower mpg around town.
Old Nov 15, 2013 | 07:41 AM
nojoke327's Avatar
nojoke327
My mpg went up when I switched to 35s. I have 3.73 gears and was averaging 10 mpg, now after adding the tires I average 11. I say go for it.
Old Nov 15, 2013 | 08:41 AM
MT4x4guy's Avatar
MT4x4guy
Depending on your set up, the weight of the 35's will most of the time keep the mileage just about the same, you are adding a heavier rolling mass to the mix.
Old Nov 15, 2013 | 09:07 AM
Frozen_Joker's Avatar
Frozen_Joker
Hands down, change the C6 out to an overdrive trans. The only thing I use a C6 in is a trail rig or drag truck. C6 for normal use is just no good on the fuel mileage. I had a Bronco for my daily commute, when I first got it it had the C6, I swapped it out with an E4OD trans and gained about 6mpg just from that.
Old Nov 18, 2013 | 11:27 AM
Baja7.3's Avatar
Baja7.3
I've heard a truck with a c6 does not have the proper wiring for eo4d
Old Nov 18, 2013 | 12:05 PM
FORDF250HDXLT
you heard correctly.you can find an idi truck that came with an e40d and get it's stand alone computer for the trans along with the wiring harness at a salvage yard or buy an aftermarket controller.you'd have to love your truck though as it would be much easier and perhaps just cheaper to just sell your truck and buy an all running idi truck with a e40d trans already.
Old Nov 18, 2013 | 04:15 PM
Baja7.3's Avatar
Baja7.3
Man 14 on 35s sounds great lol
Old Nov 18, 2013 | 04:19 PM
Baja7.3's Avatar
Baja7.3
Yea only bought for 1200$ and has 150k miles on 4x4 so I'm happy with that
Old Nov 18, 2013 | 04:22 PM
Conanski's Avatar
Conanski
IMO 35's should help milage on this truck as long as the speedo is recalibrated for them.
sanders46
Modular V10 (6.8l)
20
Aug 17, 2012 10:40 PM
snakedoc
13
Feb 5, 2011 08:35 PM
mustangz_04
2004 - 2008 F150
Jun 14, 2007 10:36 PM
78ihs2
Apr 12, 2006 09:51 PM
Mr.BrrIce
2004 - 2008 F150
Sep 21, 2005 07:44 PM
