Hi All its been a week plus since I have posted on my issue. That's because I have not done a thing about it YET.
I am not at home near my shop, and Im not driving the truck much.
I have been driving it every other day , sometimes a couple times a day and it is running as it should, EXCEPT I had to make a few short drives and stops , again it was running fine, then it was shut off for 5 min, started it up and immediately could tell it was screwing up. Took off and IRP at 84.7 all the way home, it didn't stall but the ICP was low and not building to what it should, Thus the reason for the PCM to send the 84.7 ( closing the IRP) to build ICP to desired level. Im assuming the IRP was not responding the the OCM command.
The strange thing is I drove about a mile and No engine light came on. Whats up with that??
Once I got home, shut it off, 30 seconds, started again and the dam thing was running good again.
Is it possible the IRP is sticking fully open, and not responding to the PCM commands??
Take a look at the ICP connection , there's a grey clip that holds the 3 wires together take that off and look real close for burnt or white on the wires, start the truck and do a wiggle test to see if engine miss or acts up that would need a ICP pig tail, and you will see wack values for ICPV
Ill give that a try tomorrow. The ICP readings seem to be consistant with normal driving and the IPR values seem to be consistant too, as I have been monitoring this for a couple weeks now.
I will check the pigtail tomorrow
Yea its Intermitted , I had the same issue a while back drove me nuts, then the engine started to stall a lot more, the ICP and ICPV would be wack when it started doing this any other time would be normal, I had three dif Mechanics scratching there head over this and a few here too. If it is the pig tail its simple to do
OK, Had to take the truck out today, several short starts and stops. Befor I went out, fired her up, warmed for 5 min, checked ICP and IRP, looks normal. Popped the hood and wiggled the ICP pigtail and no change. Fine.
Whent for a drive , 2 stops and starts, on the second start, could tell something was wrong, started driving and IRP at 84.7 almost continuously and lack of power. At idle CP went down to 490, so I rev'ed it to keep it from stalling, Drove for a couple blocks ICP would not go above 900, IRP still mostly at 84.7.
Parked and shut off, maybe 10 min, Started and everything was fine, drove around town for 10 min, and made another stop. 30 min. Started and there we go again, pulled over, shut off, 30 seconds, start again and everything was fine.
I am convinced that the IRP is sticking OPEN, when the truck is off, the IRP remains Open, start it and it should close to a % determined by the PCM. This is not happening all the time.
I was thinking that it could be the IRP pigtail, since it sees a lot of heat from the drivers side up pipe, but if it was a bad wire this condition would happen randomly as you were driving.
The IPR could have the screen full of junk or suck in mite want to pull and take a look at the screen, Did you pull the grey clip off the Connection to ICP run the truck and wiggle test? may need to disconnect ICP and run the truck for awhile to rule out ICP.
I too think it is an ipr or ipr pigtail. Just as a check, Unplug the icp and drive for a while. If it does not act screwy, then it is the icp or icp pig tail. Otherwise, I would check the ipr.
I had the IRP out when I did the STC fitting. I had this condition originally, before I did the STC, dummys and SP's. When I pulled the IRP the screen was clean as a whistle. The kit I bought from ford had a new IRP screen and orings, so I changed them.
Again, the condition I have now is the same condition that started me doing all this work.:
STC fitting, dummies, SP's, All injector seals and orings,
My original problem still exists. although I did see a couple of deteriorating o rings on the dummies.
I have a new IRP on the way, ICP checked ok. When I get home on Monday I will replace the irp and try it.
Hi All, Just finished 1000 mile, 2 day trip home, and the dam truck ran perfectly WTF??
No loss of power, no funny readings on IRP &ICP. Lots of starts and stops.
I did pick up two new batts from Costco
I will install my new IRP in a few days and try to do a bit of driving to see if all is well.
I Played around with the ICP pig tail and plug while running. Shut off truck, pulled the ICP plug, inspected it and reinstalled, Started truck, and things were fine. Did that several days ago. The loss of power thing happened again after I did this.
Then a few days after that I made the 1000 mile trip home. I am pretty sure its the IRP sticking open when the truck is started. It always happens off the starting of the truck. Always when the truck is warmed up (That part doen't make sence to me).
I will change the IRP in a few days and post back to give the out come.
Oh there was one glitch, 700 miles into trip home the ABS light came on.. HMM The last time that happened was when the left front wheel bearing calved. They are expensive things. My SG II didn't pick any codes so I will plug in the AE and find the issue. Ill start new thread too.
I want to thank all who has weighed in to help me out, THis Site is the BEST!!!
IPR or VGT solenoid connector 6E7Z-12A690-DA 1878512C91
Originally Posted by npccpartsman
A graph of ICP, ICP desired, ICPv and IPR. You should be able to graph and log all 4 at the same time. At some point you'll see ICP desired above the ICP actual for an "extended" period and the P2290 will set. I don't remember the exact time that it takes to set the code, but it's not long. Certain tunes will also set the code if the ICP desired is above what the HPOP is capable of and you'll have nothing mechanically wrong with the truck.
The PCM has a desired ICP value it's looking for under a particular set of conditions (load, speed, etc) The PCM opens and closes the IPR valve to satisfy the demand for ICP that it's looking for. If the desired ICP value is not reached in a set time the P2290 code is set.
Originally Posted by cheezit
if the ipr failed to stay open you engine would shut off and you would have a 100% return back to the sump.
All really Great Info, and I would look at VGT, Turbo it self Needs A good Cleaning,. If you have really looked into the above remedy.
