Sponsored by: Real Truck
2000 superduty advice
Old Nov 13, 2013 | 10:19 PM
punishercustomz's Avatar
punishercustomz
OK guys I had a beautiful 08 suoerduty with 8" lift and 38s but with our family growing I was forced to sell her and I purchased a 2000 f250, it has 170k miles on her now the motor has about 80k (5.4 v8) has a nice steel cowl hood and a nice stance. Little rusty and I'm trying to decide if I should put money in to fixing the body rust or just get rid of her and find something a little cleaner. I would like to put a mild 3-6" range lift on it but I have no idea what's up with the suspension it has way to many springs up front and sits level, I think it has 6 leafs up front! I'm afraid if I buy a bolt on kit I'll run into problems due to someone else's hack job. Should I go ahead and buy a kit and see if I can make it work? What's the cheapest way to get a few inches of lift?
Few other problems I'd like to address eventually: driver window goes down slow and only goes about halfway and gets stuck, fuel gauge shows full at all times, front end wonders from time to time and about once a week it pulls real hard back and forth going down the road its been doing this on and off for about a month now. Talk me into keeping this puppy show me her potential!!
Old Nov 13, 2013 | 10:32 PM
punishercustomz
<a target='_blank' title=' - Image And Video Hosting' href='http://imageshack.com/i/14lwcuj'><img src='http://imageshack.com/a/img40/7669/lwcu.jpg' border='0'/></a><br>Uploaded with <a target='_blank' href='http://imageshack.com'>ImageShack.com</a>
Old Nov 14, 2013 | 12:05 PM
punishercustomz
Any input?
Old Nov 14, 2013 | 12:22 PM
Bigpipes 35's Avatar
Bigpipes 35
Nice looking truck, I would say the steering issue is due to the front axle ujoints, the get dry and cause the steering wheel to jerk back and forth. It doesn't matter if the truck is in 4wd or not.
Old Nov 14, 2013 | 12:59 PM
punishercustomz
So what should I do? How can I find out for sure?
Old Nov 14, 2013 | 01:17 PM
Bigpipes 35
Prob the easiest would be to turn your wheels with the hubs unlocked and reach behind in the open knuckle area and turn the front output shafts and see if they bind when you spin them by hand..I suppose you could also jack it up and turn the wheels with the hubs locked in and spin the tire to see if you feel any bind as you spin the tire by hand..
Old Nov 14, 2013 | 03:17 PM
punishercustomz
OK driver side spins free and passenger side will not move by hand. I made sure the hub was unlocked, so what should I do replace the joints?
Old Nov 14, 2013 | 04:43 PM
Bigpipes 35
This is an awesome write up I used to do my ball joints, this will get you to the axle joints..Ford Super Duty Ball Joint Replacement Procedure
slovride
Apr 21, 2013 10:42 PM
AndeyHall
Mar 6, 2010 07:02 AM
mrcoffster
Mar 26, 2008 09:19 PM
sapperken
Mar 19, 2008 02:29 PM
minus
Apr 25, 2002 08:28 PM
