The back of my gauge cluster is all brittle, and the plastic that holds the light sockets in place is crumbling away, so the lights are not making good contact with the printed circuit.
I was wondering if there is a good way to fix the problem, I was going try taking a plastic washer, and try and glue it around the socket hole to fix the problem. I bet that someone else has had the same problem, and was hoping to get some good ideas on fixing it.
Solder 2 wires from the bulb holder to the printed circuit or to the feed wires from the loom to get it to light, then use some clear silicon to hold the bulb assembly in cluster hole. If the bulb burns out, its no biggy to tear away the silicon to replace it
There are many threads here on this subject. This is a common problem. The main consensus seems to be to replace the plastic piece. Some people have been able to find NOS parts.
You could get the backing panel from a 80's - 90's full size ford van too - "should" be the same. I think it was mentioned in the past that they are still available from Ford.
Will it be a direct fitup to the cluster assembly ("mask" per shop manual) and printed circuit?
Any surprises we should know about or btw in regards to "should"?
You've got to be carefull about buying a replacement housing. I know I've got about 6 of them in the attic that don't fit my truck. Try our sponsors and also try Ford. Someone here got his from Ford not too long ago.
