1985 F250/460 popping, hesitation
#31
Are you trying to say there are no numbers at all?
Anywhere?
Have you tried taking a piece of sandpaper to clean any rust or scunge off it?
The numbers are on there somewhere.
I usually brighten them up with chalk or something before trying to time my truck.
But with DSII ignition I really never set timing unless I've had the distributor out for some reason.
Anywhere?
#32
Well darn, I take it your firing order is correct. I was hoping it was something simple like a crossed wire.
Once you have verified the #1 cylinder is at top dead center you can paint a line on your damper (make a timing mark) in alignment with the timing pointer and then go from there.
Also, don't know how / where you determined your fuel pressure but 2 psi is very low for an electric fuel pump system. IIRC I think they're supposed to be closer to 8 psi.
However, I'm still guessing you've got some sort of miss-fire issue. Timing is off or some kind of wiring or component issue. Ignition module, coil, distributor pickup...maybe cracked cap but I think you said you'd already replaced it.
Can't say if the wiring colors will be the same as yours on this DSII diagram, and I know my wiring is slightly different in that I don't have the bypass wire running from the starter relay to the coil, but maybe it will give you some ideas on double checking your ignition system wiring and connections.
#33
I checked for tdc #1 and it does line up to the 0 mark on the harmonic balancer (I found the numbers )
Thank you for posting that diagram I have been looking for something like that. There are 3 other ignition modules in the truck. I have always been suspicious of why he was replacing it so much.
pretty much all the wires under the hood are wrapped in electrical tape, some sat on top of the intake manifold and began to melt.
#34
Timing is the problem
I believe I figured out what the problem is. The timing advances way too much
when I throttle up.I disconnected the vacuum advance and plugged it and it still does the same. I dont know how much it advances, but it is past the numbers on the balancer.
I have re-verified that the timing marks are correct and have set the idle and timing according to the sticker above the radiator.
Just to see, I put in one of the used ignition modules that was with the truck and started it up. I gave it gas all the way to 4000rpm and the was no miss or stumble, but then when i tried it again it went back to same problem. I'm not sure if the module would cause the advance, but I figured I would ask you guys before I spent money.
#35
#37
#40
You are correct but for Windsors...they used both firing orders. 302 HO used the 1-5 firing order, same as the 351 and 351 HO. 351W I believe always used the 1-3 order until they changed it to 1-5 apparently to save some stress on the internals or something. 302 same deal I think. I run a 302 on a 351, since the cam is for a 302. No issues here.
I've never heard of a 460 running a 1-3 order.
Edit: didn't realize it's on the 3rd page when I wrote that. Carry on.
#41
#42
If you have 20* of crankshaft rotation before the rotor moves, the timing set is shot.
This would explain why it is spitting back through the intake (and why I asked two pages ago)
Factory nylon cam gears are good for about 60k IME.
Do a little more diagnosis before you go tearing into the front of the engine.
#44
No, it should not. Depending on which engine, there's a certain amount of timing slack allowed. Usually the tolerance is between 3* and 5* of timing slop. Your timing set is shot. I don't know how it's even running like that. I pulled apart an FE with about 8* of timing slop and it barely ran.
#45
I just realized you said in post #37 "I can turn say 20* before the piston would start to move, or the position of the rotor"
I'm sorry, if I misunderstood.
The piston is connected directly to the crankshaft.
You are talking about turning the crankshaft bolt with a breaker bar or similar, correct?
How are you determining piston movement?
