turn signal relay buzz
Old Jun 22, 2003 | 04:01 PM
dwetopgun's Avatar
dwetopgun
Angry turn signal relay buzz
ok guys i have searched and havent come up with any help yet so im asking.
i have a 1998 explorer xlt, i've had it for about a year and a month after i bought it the turn signal relay started making a noise. it sounds like a lie detecter, some times it is just a light tick, tic-tic, but then sometimes it just make a screeching buzzzzzzzzzzz. it dosent do it once the turn signal is being used only in the rest position. i have changed the relay twice and no luck.
PLEASE HELP
Old Jun 30, 2003 | 02:41 PM
rbenton's Avatar
rbenton
Any luck??? I have a 97 Explorer xlt that "sometimes" buzzes but only when using the turn signal, never at rest. I am curious to get this fixed!
Old Jul 1, 2003 | 07:18 AM
mason's Avatar
mason
Typically the buzzing when you use your turn signal is caused by a faulty multi-function switch in your steering column. Easy fix, costs around $55 at the dealer. Be sure to disconnect your battery before working on the steering column. I haven't heard of the buzzing at rest before.
Mason
Old Jul 2, 2003 | 08:32 PM
ru2112's Avatar
ru2112
I have the same Issue on my 98xlt, it will buzz while in turn position but not if I hold it like to change lanes. I also have a problem with the Windsheild washer not working, it's probably the the same switch!
Old Jul 3, 2003 | 07:26 AM
mason's Avatar
mason
The multi-function switch operates the high beams, wipers, windshield washer, 4 way hazard lights and turn signals.
Mason
Old Jul 6, 2003 | 08:17 PM
ru2112's Avatar
ru2112
I fixed the problem with the turn signal buzz and the winsheild washer not working. I took the Multifunction switch out and took it apart. Very dirty contacts, I think the contacts are copper plated and they were green and dirty. I used some contact cleaner and a wire brush, then I wiped it clean. Then I took a pencil erase to all the contacts. Everything is now working perfectly! Took about 1 hour total.
Old Jul 9, 2003 | 04:51 PM
dudewaha's Avatar
dudewaha
I just had this repaired on my 96 XLT they said it is very common. New multiswitch solved all the problems
GermanMike
Jun 16, 2015 03:39 AM
cullenkyla
2009 - 2014 F150
Nov 18, 2014 05:26 PM
swanyman78
Oct 24, 2013 11:38 PM
Jgostrenga49855
Oct 17, 2013 01:31 PM
