fordtuff
Hey, I have a '88 F250 4x4,94,000 miles.
After 3 months of repair yesterday we took it out on the road. It is a automatic. It seems to have to work real hard to get up to speed, but does not have trouble keeping it there. Any thoughts? Also, The Steering is loose. I know its an old truck but isn't there any way to tighten up the steering?
Thanks,
Staci
What size engine do you have? You can adjust the steering by adjusting the steering box, but i don't know how, someone else will have to fill you in.
Primary rig is:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Sunroof, and some 32" BFG Muds .
Pictures are in!!
Then theres:
99' Mustang GT 4.6L
88' F-250 Superduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Top speed is 65mph, Go Baby Go!
to tighten your steering your going to need a wrench and a flat tip screwdriver. On the top of your steering box you'll see a bolt sticking out that has a slot in it,,and a jam nut on it. Loosen up the jam nut, tighten the bolt, slowly...go a quarter or less turn a time...tighten the nut and test drive it.
