Rims
Old Nov 9, 2013 | 10:06 PM
Vinford's Avatar
Vinford
Rims
Is there such a thing as 15" 8 hole rims?
Found some nice 15" tires Id like to put on my 78 3/4 ton
Old Nov 9, 2013 | 10:20 PM
jswartz84's Avatar
jswartz84
Yes, I don't think they are very common but I have seen them on craigslist.
Old Nov 9, 2013 | 10:54 PM
paredneck33's Avatar
paredneck33
yes there is. that was a common replacement a lot of guys with the 3/4-1 ton trucks would switch out back in the day cause tires for the 15's were cheaper than the 16-16.5's. also I believe they where 15x8 which offered better stability then the 16's/16.5's that where only 6" wide when the truck has a load on it.
Old Nov 9, 2013 | 10:58 PM
spikinfool05's Avatar
spikinfool05
well they are kinda hard to find and really dont fit the trucks with disc brakes all that well. i have few sets of them and they fit my 74 well but it has drum brakes on the front. rumor has it if you grind the front caliper down they will fit but as i have never done this i cant tell you if its true or not. what i do know is they will not fit around the dual piston caliper at all.
Old Nov 9, 2013 | 11:50 PM
Sooper Camper's Avatar
Sooper Camper
they'll fit, they are just hard to find and more trouble than they're worth. they also usually have 2.5" of backspacing, so they stick out really wide and have a terrible scrub radius. i ran some for a while on my 1 ton bronco and was glad to get rid of them. good thing they were free!
Old Nov 10, 2013 | 01:37 AM
stromburg's Avatar
stromburg
You can get them from Summit for around $60 and Les Schwab has them, also you can get different backspacing, the advantage for running less backspacing like 2 1/2" is so you don't have to grind as much off your calipers if you have disc brakes up front.
Old Nov 10, 2013 | 01:41 AM
Skip1970's Avatar
Skip1970
i got a set and they are sweet, chrome wagon wheels. 15" 8 lug.
Old Nov 10, 2013 | 04:03 AM
shane_lxi's Avatar
shane_lxi
Most 15" tires are going to be 4-6ply though, so you'll be more limited to lighter duty tires.
Old Nov 10, 2013 | 09:09 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
All day long on the Summit for new and Craigslist for used, and yes you could have some caliper clearance issues and 6 to 8 ply tire issues.
73-79 Ford F250 Mud Truck
Old Nov 10, 2013 | 10:31 AM
montana_highboy's Avatar
montana_highboy
Break out the bank book...
AKH Vintage Wheels - Vintage Rally, Styled Steel, and Alloy Wheels
Old Nov 10, 2013 | 11:42 AM
77&79F250's Avatar
77&79F250
I have a set of 8 lug 6 1/2 15's aluminium slotted mags. They are 8" wide fronts and 9" wide rear's, but look to be more for a 2wd truck IMO.
Not really wide enough to put some 33's on.
Old Nov 10, 2013 | 11:50 AM
montana_highboy
Post up pics....
Old Nov 10, 2013 | 01:04 PM
77&79F250's Avatar
77&79F250
Ok well here you go, fronts are 15x7", "Shelby Cal 500", rears are 15x8.5, I was guessing my widths in my earlier post.
2nd to last pic is my slotted mag 16.5's and couple of sets of 16.5 hurricanes/fins rims.
I sold my 16.5 ALUMINIUM spokes
Old Nov 10, 2013 | 01:13 PM
77&79F250's Avatar
77&79F250
The day will come when it all gets sold sold....
Old Nov 10, 2013 | 06:01 PM
Blue and White's Avatar
Blue and White
The dual piston calipers common on 3/4 ton are a tight fit with 16's... some fit and some don't. With 15" I think the dual piston would be a no go.
