Steering gear condition help
Old Nov 9, 2013 | 04:34 PM
obscurity's Avatar
obscurity
I have removed the steering gear and taken it apart and this is what I have. I do not know much about gears but I assume this is not usable correct? There appears to be paint on the gears or maybe it is just baked on grime. Is that normal?
Old Nov 9, 2013 | 10:32 PM
newold46's Avatar
newold46
It looks like it was packed in grease once upon a time. Soak them in some parts cleaner or brake fluid for a day or three and see how much comes off. As long as they mesh properly and there is no binding, they should be usable. Mine looked something like that, minus the thick grease and they seem to work fine. Like everything else on these trucks, the gear box is simply made and takes lots of abuse.
Old Nov 10, 2013 | 10:00 AM
christurney77's Avatar
christurney77
Mine was similar as well. I replaced, because the "dead center" location was actually worn thin enough to visibly see. If you don't have that, I would say you are good.
obscurity
17
Dec 1, 2013 07:30 PM
DieselHardware
Jul 18, 2011 09:33 PM
chester1964
Nov 24, 2003 09:35 PM
