I put these on a few years ago after seeing them on my father's F250. His have made it through 4 PA winters so far and the don't show any wear or damage. I've had mine for 3 years now but don't get much ice accumulation on them here in NC.
They are the husky liners but unfortunately they do require drilling 1 hole on each rear guard.
Opted for the Ford Custom Accessories splash guards - part # 6L3Z-16A550-BA (set - includes front and rear).
rears - no-drill installation.
fronts - made it a no-drill installation by using 3M™ double-sided attachment tape. *note: normal is a drill installation - 2 holes per side into the wheel well flares.
I just finished putting a set of mud guards on all 4 wheels made by DeeZee. These are no drill installation and it took about 15 minutes to install all 4 and the cost was $63 including shipping.
Is there any drilling on the front ones? I was thinking about getting front only.
Thanks
I just went to the mfg's website and it turns out the front ones also require 1 hole to be drilled for each guard. Sorry, it's been a few years and i only recall the rear ones being drilled.
A quick coat with some touch-up paint after drilling the hole should keep rust at bay... you would just have to drill the holes one day and install a day or 2 later.
