Go through the driver side fender well and clean the area off where the oil cooler connects to the block. An iPhone with the camera is the way to go because it can fit in there to get a photo of the area.
In order th have PMR's the engine would have to have been changed with a newer engine out if a SD. And if that was the case then you'd have e fuel unless they changed the cam
