I'd appreciate hearing from anyone that has actually removed the block plug (from where ever it is) and installed a heating rod...I'm fairly mechanical, just not sure of the steps or tools needed.
I pulled the right front wheel and then removed the fender liner. Cleaned the area, covered the starter with plastic and got the heater ready to install. I then quickly removed the plug and swapped in the heater losing just 10 oz. which was caught in a pan and returned to the radiator. There is no need to drain the coolant, just practice your moves and work fast. Sorry, I don't remember the tool sizes. I ordered the heater from a Ford parts supplier and used an after-market cable that cost far less than the Ford cable. I put a cover over the cable to protect it.
These trucks don't come with a block heater as standard equipment?
Only if it was shipped to 11 or 12 states I believe. Yes, I too had a LONG discussion with my dealer about that too. I will have one put on soon, or now after seeing this, tackle it myself!
Bummer. I guess everything is becoming 'a la carte' these days....
They claim that unless it is -10* or below, the truck should start fine. That is not my point. I want it to be warmer WHEN it is started to help with wear and idle time before heading out in the truck somewhere. It's got to be easier on the engine.
Good answer, folks say that they can get it started at X below zero but that ain't the point. Any engine will benefit from a warmer starting point. My dealer in PA just didn't understand why I wanted a block heater. I guess that the truck should only be driven South from here?
I have the block heater but never used it as it's in the garage when at home. The supplemental cab heat is the best option I ordered though. Heats up the cab faster than any gasser. I imagine if we head north for some sledding trips this winter, we'll plug in though. It's often below -10 when your getting ready to leave in the AM. Fort Kent ME can get a little chilly from time to time...
wow I thought the block heater and cab heater was standard but I talked to my dealer and they order all the trucks with it I believe, I love it! blows warm air almost right aways!
Yeah I think the block heater is standard in Canada.
