my 06 was lowered when I got it. it is missing a leaf spring so when I hit a hard bump it will bottom out. id like to put a leaf back in and add a flip kit.
will the leaf springs from a 97-03 f150 bolt in my truck? there are plenty of those at the you pull it. didn't see a single one my body style
The leaf spring you currently have on your vehicle is most likely going to be 3" wide while the leaf springs from a 97-03 will be 2-1/2" so that right there isn't going to work properly. Also the older body style's leaf springs will be slightly longer.
