1997 Ford F250 Heavy Duty
There is many reasons the E40D does this. Not trying to be a jerk here but there are many, many threads on this trans. Its a fully electronic trans and im not BSin when I say even your third brake light out can effect how it shifts... Run a search read up and if you need more help start your own thread... Lets keep this one on topic!
Is that true? I was thinking the GVWR was 8,600 on all F-250HD, but that the GCWR varied based on engine, trans and axle ratio.
Gross Vehicle Weight Rating is how much weight the truck is rated to carry (including its own weight) on it's own wheels. Gross Combined Weight Rating is how much it's rated to move, including itself, any payload and any trailer.
The really odd thing is that my '85 F-250HD with a 351, 4 spd and 3.55 gears had a GVWR of 8,400 lbs but a GCWR of about 7,600. So I guess I could only load it to the max if I was towing a trailer full of helium.
5.8, 3.55: 11,500
5.8, 4.10: 13,000
7.3, 3.55: 16,000
7.3, 4.10: 20,000
7.5, 3.55: 12,000
7.5, 4.10: 16000
This is from page 197 in my owners manual. Its a bit over optimistic when it does the math though, it says 0-6200 Lb. for mine which would limit my curb weight to 5,300 when it's over that by about 120 even when I'm not in it.
Those 3.55s really kill the capacity, but they make up for it in fuel milage.
Current record is 15.6 this summer, same shell station, same pumps 87 octane. I was averaging around 15 before that and it dips to the 12-13s in the winter.
I doubt I could get that with 4.10s, unless I drove slower or something. Hauling obviously dips the milage to, just hauled near my max GVWR with the bed full of concrete, cant wait to see the milage!
Just joined this forum and found this thread very useful as I just bought a 1997 F-250 HD 4x4 5 speed. I like the truck a lot and will be using it for towing a car to the track and firewood. I'm glad to know I have 4.10's in the rear and that I didn't get stuck with a 1998 F-250! Great info!
Or put a white mark on the drive shaft and one on the tire. Have someone move the truck forward slowly and count how many times the driveshaft goes around for one revolution of the tire. In a '97 F-250 it'll probably be about three and a half times (3.55:1), about 3 and 3/4 times (3.73:1) or a little over 4 times (4.10:1). F-150s might be lower numbers.
Or with a 4WD with manual hubs you can do it by yourself. Lock the right hub, lay under the truck and turn the drive shaft while you watch the U-joint in the left steering knuckle. Because of the differential the axle will turn twice as fast as the gear ratio, so the driveshaft turning a little over 2 times for one axle revolution is 4.10:1 and so on.
You can do this with automatic hubs too, but you need to jack up the left front tire because the hub will lock and you need to let the tire turn or you won't be able to turn the driveshaft.
If you look at the back of the passenger side front ttb there should be a bill of material number. 610609-1 3.54
610609-2 4.10
610609-3 3.54
610609-4 4.10
610740-1 3.54
610740-2 4.10
610740-3 3.54
610740-4 4.10
I found that info on the spicer website with a sheet that has all of the spicer numbers for seals and axles and such.
610609-2 4.10
610609-3 3.54
610609-4 4.10
610740-1 3.54
610740-2 4.10
610740-3 3.54
610740-4 4.10
#29
