P1450
Old Nov 1, 2013 | 09:22 PM
hullfm's Avatar
hullfm
P1450
just wondering if anyone has had any experience with a P1450 code on a 04 ranger 4.0 liter, automatic, not a whole lot if info out there so i thought i would chime in, it says unable to bleed up fuel tank vaccum. i dont think its the gas cap and looks like the tank pressure sensor is a dealer item, thanks
Old Nov 2, 2013 | 05:17 AM
03 Maz B23's Avatar
03 Maz B23
Ran a search and found the following:
That is an evap emmissions code - wont release vac here is fords description
P1450 - Unable to Bleed Up Fuel Tank Vacuum Monitors the fuel vapor vacuum and pressure in the fuel tank. The system failure occurs when the EVAP running loss monitor detects excessive fuel tank vacuum with the engine running (but not at idle). Blockages or kinks in EVAP canister tube or EVAP canister purge outlet tube (between fuel tank, EVAP canister purge valve and EVAP canister)
Fuel filler cap stuck closed (no vacuum relief)
Contaminated fuel vapor elbow on EVAP canister
Restricted EVAP canister
CV solenoid stuck open (partially or fully)
Plugged CV solenoid filter
EVAP canister purge valve stuck open
VREF circuit open (harness near FTP sensor, FTP sensor or PCM)
Damaged FTP sensor
THat being said I would ck the canister vent solenoid and hose[attached to evap canister] for an obstruction. you should be able to blow through the valve and hose freely.
Old Nov 2, 2013 | 08:50 AM
pawpaw's Avatar
pawpaw
Nice detailed DTC info post 03 Maz B23.
Purge valve & gas cap problems have been posted about, so they belong high up on your suspect list.
If its wanting to stall after a 30 min/15-20 mile drive, suspect the gas cap, so pull over & loosen it to relieve the tank vacuum & see if engine power goes back up. If so, replace the gas cap. If no joy, look to a stuck open purge valve, maybe try thumping it to see if it'll wake up & function. Let us know how your trouble shoot goes.
Old Nov 3, 2013 | 05:29 PM
hullfm's Avatar
hullfm
thanks for the replies guys , i found some good info on motorcraft web site about this it is and is way more complex than it needs to be, i got a chance to work on it this weekend, I took the canister valve off and checked it out, seems to be good , no air would go thru it and then i jumpered power to it and it opened as it should so i put it back on and took the gas tank fill vent off and it was clear also, sucking in on the gas cap cap relieves suction also (runs fine , never wants to stall and no sounds when cap is removed ) so i think the cap is ok also, so i put my code reader back in and read the flash results and found some funny numbers, it said air intake temp was like 20 degrees or something and engine temp was 88 degrees, that is as far as i got, working 12 hour nights this week , a friend of mine has a live data scanner so i can check those two items plus the fuel tank pressure output if it will scan that im not sure, i suspect its the tank pressure sensor but want to be sure before i buy one, all other lines look good from the outside , no kinks or somthing like that, thanks again
Old Nov 13, 2013 | 02:45 AM
hullfm's Avatar
hullfm
just an update, the live data scanner I borrowed did not pull up the pressure sensor but the intake and engine temps were normal, bad thing is new pressure sensor from Ford is 200 bucks and comes as an assembly with lines attached to it so the tank and canister need to be lowered in order to get at the lines. (or remove the bed) I have one more test to do and that is I should have a 5 volt referance wire going from the PCM into the sensor and should have 2.625 volt signal going back to the PCM, that will tell me if the sensor it reading right at atmospheric pressure, or could be no power or bad ground witch will throw a P 1450 also,, more to come
Old Nov 13, 2013 | 06:52 AM
pawpaw's Avatar
pawpaw
Good trouble shooting idea to do voltage & ground checks on the vapor recovery system. Grounds are a common problem.
If you haved to remove things, members that have done it, say sliding the bed back to get at the fuel pump, is way easier & less complicated than dropping the tank. Unkook the tank fill tube, & rear taillight wiring harness, remove the tailgate to make it lighter, remove bed bolts & slide the bed back to rest on some saw horses & the rear tires.
Will be interesting to hear how your trouble shoot goes.
Logan Sorensen
Escape & Escape Hybrid
Feb 4, 2020 12:07 PM
Ole' gray
Mar 2, 2019 08:50 PM
lincolnboy73
Aug 31, 2010 06:56 AM
Furyus1
Jul 23, 2009 09:40 AM
snifferdog
Dec 20, 2003 09:01 PM
