I'm so excited!
Maybe I'll do the same.After I posted last time I took a wire brush to some of the rusty spots on the outside and found quite a few pits.No pinholes but they were kinda deep.Truck Shop and LMC have new ones for 200 plus shipping.But if I put the tank out back that leaves me room for a tool box behind the seat or something to that effect.I plan on working the truck occasionally when I tear off a roof or somethin'.Puttin a tank between the rails out back won't be too hard to do.Maybe I'll throw some nice bucket seats in with that extra space .Thanks guys!
Hey Toby,
Listen to Wayne on this one. It's not worth it to mess with an old gas tank full of rust, pin holes, & stuff. We bought a mustang tank from Rock Auto for $120 & put it under the bed out back. Looking back after our build - I'd recommend replacing gas tanks, radiators, gas lines, & brake lines.
Hang in there.
Ben in Austin
1950 F1
Hang in there.
Ben in Austin
1950 F1
Thats awful good advice even if funds are an issue or what have you . It ends up cheaper in the long run 9-1/2 times out of 10 to do something right the first time . And Welcome to the Forum .
Thanks for the advice guys,I plan on replacing the fuel and brake lines for sure.Prolly the M/C too.And a new tank is the best route to go,but I think I wanna try this electrolysis thing first.It'll cost me about 20 bucks to do it.Not that I'm cheap but the curiosity factor has got me.I guess they don't boil out tanks any more.One fella I talked to said he charged 150 to boil and seal them.Doin' this tank will be like an experiment for me sinceI'll prolly have other stuff to clean up later.
Sorry no pics yet,I know you guys like em but my camera's not home yet.The lens on my phone is all scratched up so it don't take so well.I had thot maybe using some of that gray foam pipe insulation to keep the electodes from touching the tank thru the filler neck hole and the sending unit hole. Gonna build a tub out of 2x4's and OSB and line it with some of that plastic they shrink wrap boats with.Heavy blue stuff prolly 8mils thick. I gotta finish building some cabinets this weekend so I'll have the shop warm so my glue will dry good,should help the tank cleaning a little ,I hope. That reminds me, I gotta bring some wood in,UGHH.
Well I got my camera now.Gonna head out to the farm and take some pics.Tried the electrolysis thing ,couldn't get it to work just yet,but I haven't given up .I'm kinda frustrated tho tryin' to find out which model, make and years of motorhomes have usable rims on them.Found a couple Winnebago's on craigs list but they want bookoo bucks for 'em.Maybe Stu the wheel guru can steer me in the right direction?
Thanks Stu. I was wondering about international school buses,I know a fella that has a couple .I had pulled an Alison trans out of one and put it into one of his one ton trucks. He had a tree service years ago. I spose I need to try and match tire size somewhat?Anyways thanks for the reply.
#28
I like keeping the old trucks stock. I have had good luck with a radiator shop cleaning out and sealing gas tanks for me. Less expensive than a new tank, bolts back in where I took it out from, and no rust or leaks in 10 years. Just got the 5th or 6th tank cleaned by them last weekend.
I bought a new tank for less from Speedway & it was here in a couple of days. There's also an ebay seller with free shipping.
By the way....I bought the new tank after I had cleaned and resealed my old tank with a POR kit. The solder joint for the flange of the sending unit was cracked & it leaked anyway. The radiator shop would have caught that, but at that time I had decided that a $79 POR gas tank kit was going to save me around $170 bucks. It didn't work out that way!
Dan
#29
#30
There is only one local shop that will still clean a gas tank here in San Jose. The rest only want to sell new radiators in a box.
