It's November in CT.
#106
#109
Yup, that would be the one. Lack of lubrication caused a gear to chip, and the ensuing chaos munched up the rest.
For anyone interested in mechanical carnage:
2013-11-09 Sienna Differential Failure Slideshow by tomboy376 | Photobucket
The F150 got the same 3.73s that it had before; it was warranty work to correct a gear whine between 50-55 MPH when under throttle. The interesting part is that it's still whining! Going back to Seraphin Ford later this week for them to check it out.
#111
Wasn't full of anything! Badly underfilled from the factory; when the dealer pulled the drain plug nothing came out. I don't think that's rust either, but I'm no expert.
72,000 miles on the van, and it's only three years old.
#114
Good Morning Folks,
Finally got finished with rebuilding oil cooler and installing oil bypass filter.
Spent a lot of time under the cab with a wire brush and rust converter paint while waiting on the oil cooler parts. Hope it helps!
Did oil change with Mobil 1 5W-40 and installed Fumoto Drain Valve. Today will finish up with greasing the front end. Gotta get some Fluid Film on Monday. Saw Kahn's Tractor on the list of local vendors. I don't live too far from them. Looks like good weather until Tuesday. Hope to go back to work on 11/18. Neck surgery seems to have been successful.
Take Care,
Jim
Take Care,
Jim
#115
#116
Good Sunday morning CT ers !! Soggy with a chance of sun here today. Just having a little Sunday coffee before I satart the excitement for the day.
Great video Tom. Thanks for sharing that. Great move pulling the fuse! Not sure I would have thought of that! Quite the devastation in that rear!!! WOW!! They cover that under warranty for you?
#117
And hell no they didn't cover it under warranty; that was over 12,000 miles ago. They agreed to cover $750 of the $1500 bill though, and I'm waiting for their check. I'm gonna pursue this a bit further though, as this was an assembly error I feel they should cover the entire cost. We'll see.
#118
Well, that was a awesome tip from him! I can't believe the lack of oil in that diff !!! No sighns of leaks throughout its life I assume. I'm also surprised the repair was only $1500. I would pursue the issue a bit more myself. Seems they should use your unfortunate experience as a tool for future issues. Guess thats why I'm not in charge of that kinda stuff. LOL. Half the cost being covered is a start, but my guess is $1500 was onlt the start of your grief
#119
#120
Rear diff leaks ARE one of the more obvious, I agree. Had one or four in the truck through the years Seems a little suspect to me. As I said before, seems like a worthy pursute to me Tom. Glad you shared this info. Keep us informed of your dealings. Very interested to see how this plays out. The oil either had to go SOMEWHERE, or it just wasnt there!! Seems the later may be a more real scenario.
