Bronco II Ford Bronco II
6v Fuel Pump Voltage?
Old Jun 21, 2003 | 12:18 PM
eoffshore's Avatar
eoffshore
Replacing the burnt up mess resulting from fuel pump short.
I'm only getting 6v on the pink/blk wire feeding the fuel pump. Is that normal?
Old Jun 25, 2003 | 02:26 PM
pozner's Avatar
pozner
Don't know your year, but the diagnostic check in my repair manual says to connect a 12 volt source and a ground to the pump to test it. I'm pretty sure you should have 12 volts. Check your meter on the battery.
Old Jun 25, 2003 | 07:01 PM
Ken00's Avatar
Ken00
You should trace the circuit back until you find 12v, if you need a wiring diagram I have one that I scanned from my 1989 Ford manual, email me and remind me what you need.
Steve in NC
Nov 10, 2014 05:24 AM
Piffery1
1997 - 2003 F150
Sep 9, 2013 05:06 PM
Johnlwlr
Modular V10 (6.8l)
Mar 27, 2011 09:45 PM
Blownup5.0
Jan 7, 2004 12:32 AM
