Help decoding another 9" rear end
Old Oct 28, 2013 | 09:11 PM
Ste14mi's Avatar
Ste14mi
Had the opportunity to pick up another Ford 9" rear end on the weekend which I think will be more appropriate to my needs. Am having some difficulty decoding the axle tag however. PO says it is from a 1971 F100 and the date code on the tag seems to support this, but I can't find a reference for the axle code WDM ADD - closest I can find is a WDM AD.
The full tag reads:
WDM ADD 1F30
3 25 9 S311B
I'm pretty sure from the tag it is a 3.25 ratio, 9", with a build date of 1971/Jun/30. Don't know if it is 28 or 31 spline.
The only table I found was on FORDification and does not list a WDM ADD.
Ford Rear Axle Assembly Identification - Page 03 - FORDification.com
My objective is to know where it came from for sure so I can order the proper new brake components. I can see that it had 2.5 inch brake pads but I don't know what size bore the wheel cylinder should be - there seems to be a wide choice from 7/8 all the way up to 1 3/16.
Old Oct 28, 2013 | 10:04 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It doesn't have existing wheel cylinders? I have a '70 9" out of an F-100, also a WDM, these are the brake parts I used (also 2.5"):
Rear axle seal NAPA 15142
Rear wheel bearings NAPA 88128R
Backing plate gasket NAPA 55036
Brake hardware kit: NAPA 2241
Left wheel cylinder NAPA 17507
Right wheel cylinder NAPA 17508
Old Oct 29, 2013 | 08:50 AM
Ste14mi's Avatar
Ste14mi
Thanks for the quick reply ALBUQ F-1.
No it came with the backplate, drums & shoes only - thus my question.
In my research I saw the NAPA cylinders you mentioned. These are also Dorman part numbers and are listed as 7/8" bore and for the 1/2 ton series. What is causing me concern is that NAPA also shows UP36057/8 and UP18290/1 and these are 1 1/8" bore which I thought might be appropriate since the shoes are the almost largest possible at 2 1/2".
I obviously have a lot to learn.
Old Oct 29, 2013 | 04:55 PM
raerjim's Avatar
raerjim
Kevinstang's Ford Nine Inch Differential Page + Try this Steve.
252slater
Large Truck
Feb 15, 2018 08:48 AM
JIW74
27
Feb 23, 2015 11:13 AM
Ste14mi
Oct 29, 2013 06:49 PM
gahi
Feb 13, 2006 07:06 AM
Rosati
Aug 31, 2002 02:49 PM
