AC Compressor Clicking
Old Nov 17, 2013 | 09:38 AM
  #31
mahause's Avatar
mahause
Thanks for all the help Alloro. I have the coil on order. No Ford dealers or parts houses in the area stock this item. Will I be able to install it with out a special tool?
Old Nov 18, 2013 | 10:18 AM
  #32
alloro's Avatar
alloro
It should press on by hand. Just use caution and try to press evenly, you don't want to distort it.
Old Nov 20, 2013 | 08:36 PM
  #33
mahause's Avatar
mahause
The old coil is not sliding off easily. I have tried to pry it off and tap all the way around it. I'm going to try to get a puller in there. I can see another big snap ring in there. That doesn't need to come off also does it?
Old Nov 21, 2013 | 10:04 AM
  #34
alloro's Avatar
alloro
Try it, I don't remember there being one, but my memory seems to be less perfect the older I get.
Old Nov 21, 2013 | 11:07 AM
  #35
mahause's Avatar
mahause
I found a green drop of fluid when trying to get the coil off. This probably means I need to replace the whole compressor since a seal is leaking? This has turned into my most frustrating project yet.
Old Nov 21, 2013 | 04:07 PM
  #36
alloro's Avatar
alloro
Green is anti-freeze, you sure there isn't a leak above the compressor?
Old Nov 21, 2013 | 09:18 PM
  #37
mahause's Avatar
mahause
My antifreeze is orange. I have read that the green fluid is the compressor oil mixed with dye.
Old Nov 22, 2013 | 06:29 AM
  #38
projectSHO89's Avatar
projectSHO89
You've reached the point where a new compressor is called for now that you have new information. No use trying to fix this one if the main shaft seal is leaking as you'll just end up replacing it anyway due to leaking refrigerant.
Old Nov 22, 2013 | 04:04 PM
  #39
alloro's Avatar
alloro
Although that is a possibility, most A/C dyes are red, not green.
Old Nov 22, 2013 | 06:32 PM
  #40
projectSHO89
I've only seen green UV dye in that generation vehicle.....
Old Nov 22, 2013 | 06:53 PM
  #41
alloro's Avatar
alloro
Hmm, you must use different stuff than me. The UV dye I use is clear but turns green only when exposed to the UV light.
Daytona F1
2015 - 2020 F150
Aug 19, 2017 09:25 AM
pecanflyboy
Nov 5, 2012 12:33 PM
brad53
Sep 16, 2008 07:02 AM
Lakeitel
Oct 6, 2002 12:37 PM
Mr Baja
1978 - 1996 Big Bronco
Nov 30, 2001 01:38 AM
