Pinion angle change?
Old Oct 25, 2013 | 11:56 PM
CC_Brunner's Avatar
CC_Brunner
Its a 78 F150 4x4 reg cab long bed. I'm installing a 6in suspension lift and I was wondering as to whether or not I'm going to have to change the pinion angle on either of the axles?
Old Oct 26, 2013 | 09:52 AM
rogue40's Avatar
rogue40
Short answer, yes.
The front will probably need to be corrected using caster bushings to correct the caster angle.
The rear will have to be rotated up to correct driveline angles. Angle shims can be used in the rear but I prefer to move the spring perches.
Old Oct 26, 2013 | 02:31 PM
CC_Brunner's Avatar
CC_Brunner
Got it. Is this something I can do myself or does it require some special tools?
Old Oct 26, 2013 | 03:19 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
You can order both the rear shims and front caster bushings and install with basic tools, no welder required. lol Moving the spring perches will require a welder....
Do not forget a trac bar drop bracket or a adjustable trac bar, either will work. And are you going to use a drop pitman arm and get longer brake lines?
Old Oct 26, 2013 | 07:27 PM
CC_Brunner's Avatar
CC_Brunner
Yup they come with the kit, I was just going to get a moog trac bar. I want to put dual steering stabilizers on it, but I can't find a trac bar that had the connections for it.
Old Oct 26, 2013 | 07:35 PM
CC_Brunner's Avatar
CC_Brunner
Also what degree do you recommend?
Old Oct 26, 2013 | 10:51 PM
77&79F250's Avatar
77&79F250
Ask the lift manufacture, I am sure they have that answer in their tech dept. 6" lift maybe like 7 degrees on the front is something I remember reading somewhere, I am WAGing it. WAG='s wild **** guess, lol
Is the Moog trac bar adjustable? I am not a 1/2 front end lift kinda guy, but I understand that a drop pitman arm, trac bar drop bracket and a adjustable trac bar is the set up to use.
6t6merc
Sep 8, 2016 09:46 PM
dixiemudder04
Offroad & 4x4
Jul 4, 2006 03:58 PM
conter4x4
Offroad & 4x4
18
Sep 20, 2005 10:24 AM
ftballman125
Offroad & 4x4
Jan 21, 2005 05:49 PM
rem_243
Sep 27, 2003 12:46 AM
