I have an '86 F250 and it has the 300 in line in it with a 4 spd manual. I also have an 83' with a 460 in it and an automatic transmission. I want to put the 460 into the '86 after I remove the 300.
Got it. Thanks. To do that properly you will need several things from the 83, including the perches. But, they are NOT easy to get off as most of them have many rivets in them, which don't come out until you drill a hole through them even if you grind the heads off.
Also, I think you have another problem - the radiator. I'm sure you know that the 460 takes a different radiator than the 300 as the inlet and outlet are swapped. But, I'm pretty sure the radiator size as well as the core support are completely different between the 83 and the 86 - so much so that you cannot swap the radiators w/o swapping core supports. I'm not 100% sure of that, but I know that the change was between 82 and 85, and I think the 83 has the early style core support.
I should be able to remove them on the '86 and use the ones out of the '83 shouldnt I?
If you mean the perches, then yes. With a lot of work, broken drill bits, and exasperation. Someone, Shaun I think, worked out a process to do that: Grind the head off with a right-angle grinder or a die grinder w/a carbide burr, and then drill a hole through the middle of most of what's left. Said hole should be 1/4" or larger, and it serves to relieve the pressure of the material on the sides of the holes. Otherwise they do not want to come out - at all.
Once you have them drilled out you can punch them out. With them out and the bolts removed (one side has both bolts and rivets, IIRC) you can swap them to the other frame. Use at least Grade 5 bolts, if not Grade 8's, as well as washers and lock washers. You do not want them to come loose.
Well, you will have to remove the original ones anyway, so why not perfect your skills getting them off. Then you'll know how hard it is and how much you are willing to pay so you don't have to do it again.
I just took off the engine perches on my parts truck, the drivers side had 4 rivets and 2 bolts. I ended up using a air chisel and it worked great. After I chiseled the rivets off the perch still wouldn't come off, so i took the air chisel and wedged it between the perch and the crossmember, pulled the trigger and it came right off. I don't know why ford thought they had to use bolts and rivets on one side, and just bolts on the other side.
