The important number is stamped into the passenger side top frame rail in the area of the axle. Usually hard to see. It is not officially a VIN as we know it today.
And BTW, welcome to the forum.
You should also have a plate on the inside of the glove box door and a data plate on the firewall. But the only one that is recognized is the stamping in the frame. It will actually be in front of the axle alongside the radiator.
I have stopped working for the night. I will be looking in the morning first thing. Will let you know if i find it. Do you know how long the # is? Thanks
It should be somewhere around 9 characters. It would start with either a 98RC, like mentioned, or 98HC. The rest of the characters after that should be five or six numbers - the serial production sequence.
The number on the frame is usually on the right frame rail slighlty forward of the front axle. You'll need a wire brush and a flashlight. The number would be easier to access with the right fender (inner/outer) removed.
(Beginning) 1948 Ford/Merc trucks, 1949 FoMoCo Passenger Cars are registered by their specific VIN's (Vehicle Identification Number) which registers the entire vehicle.
Prior years, FoMoCo vehicles were registered by their specific engine number, which was also stamped on the hogshead (bell housing).
The problem: If the engine was changed, the numbers no longer matched.
While the Rating Plate says Serial Number, in actuality, the serial number is the last 5 digits (1948/60) of the VIN ~ the "Numerical Sequence of Assembly" ~ the trucks specific serial number.
1961 thru today: The serial number is the last 6 digits of the VIN
Also was wondering there a hole in the passenger side of my cab behind the kick panel. Is it for an air vent? Thanks
I have no clue, have very little knowledge inre to these trucks (1948/52). Never owned, driven or even sat in one. I'm waaay too big to fit in the cab.
The first truck I rode in was a new 1950 'advanced design' GMC pickup, the doors were lettered P. A. Eckles Oldsmobile - phone AD 3-5281 This was the parts delivery truck for grandpa's Olds dealership.
By the time I was old enough to drive, couldn't fit in these cabs either.
