Snow plow prep questions
Old Oct 23, 2013 | 03:14 PM
strokin83's Avatar
strokin83
Does anyone know the lift difference between the stock front coil springs and the snow plow prep. My '12 had the prep and my new one doesn't. The new one looks pretty squat in the front. I'm afraid of how low it will be once I put a 350lb bumper and winch combo on the front.
Old Oct 23, 2013 | 03:31 PM
2ndStroke's Avatar
2ndStroke
Bout a inch in difference I believe
Old Oct 23, 2013 | 03:53 PM
720Deere's Avatar
720Deere
On an F250, there is a possibility that you could have 5200 lb springs. The snow plow package is 6000 lb springs. The difference between my truck with 5600 springs and my brothers truck with 6000 springs is only about 1/2". From the 5200 to the 6000 spring would be about an inch. Check your door sticker to see what front spring code you have.
Old Oct 23, 2013 | 03:56 PM
blkout50's Avatar
blkout50
It's funny that you ask that. I just installed the snow plow pkg spings on my 2013 F350 which are 6000lbs capacity. My original springs had a 5600lbs capacity. I did the spring swap in two hours in my driveway.
Not sure what front springs you have (check your door sticker) on your F250, but my 2012 F250 had 5200lbs springs in it. I am pretty sure you will need the 6000lbs springs also judging by the f250 specs for the snow plow pkg.
If you need more info let me know.
Old Oct 23, 2013 | 04:29 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
You should be able to find some 6000 lb ones pretty cheap (they are easy to swap) from people putting a decent lift on their trucks.
Old Oct 23, 2013 | 10:39 PM
Powelligator's Avatar
Powelligator
I ordered my F-350 with the Camper Package, which cancels out the Snow Plow Prep and the Heavy Service Front Package. Anyone know if the Camper Package includes the 6,000 pound springs? I'm going to be putting a 12K winch up front which ought to weigh around 100 pounds.
Joe
Old Oct 23, 2013 | 10:58 PM
blkout50's Avatar
blkout50
Joe, I think the answer to your question is yes. You can check the spring tag and verify.
F-Super Duty Monobeam Coil Spring Rates (F250/350 4x4)
Front GAWR Rating Current Vehicle Spring Coil P/N 5C34-5310-xxx
4000lb. 5C34-5310-AHC
4400lb. 5C34-5310-AGC
4800lb. 5C34-5310-AFC
5200lb. 5C34-5310-AEC
5600lb. 5C34-5310-ADC
6000lb. 5C34-5310-ACC
Old Oct 23, 2013 | 11:25 PM
Powelligator
Copy-Paste-Save and I'll check the tags on arrival.
Thank You!
Joe
Old Oct 24, 2013 | 05:10 AM
720Deere's Avatar
720Deere
Joe
I'm pretty sure that the camper package maxes out spring rates on both ends of the truck.
Old Oct 25, 2013 | 01:42 PM
Jumbo131's Avatar
Jumbo131
I just checked my dually with a 13, 300 gvwr and I have 5600# front and 9000# rear. Its a 2011 with build date of 6/11. Crew cab FX4 without the snow plow package.
Old Oct 25, 2013 | 08:05 PM
T diesel's Avatar
T diesel
My 2013 f 250 camper package with snowplow prep
is front 5600 rear 6200.
Old Oct 26, 2013 | 07:21 AM
ct diesel's Avatar
ct diesel
I checked mine last night with my son and I have 6000lb. 5C34-5310-ACC 6,000 lbs springs in the front end. I have the snow package. One thing that I should note is that my 2011 sits level. Free standing in the driveway, you can put a level on the rear bed and it's level.
Old Mar 23, 2015 | 09:12 AM
Mystic_Cobra's Avatar
Mystic_Cobra
I have the snow plow prep package on my 2015 DRW and have no plans to get a plow. I would like to lower the front end an inch or two as I tow a 16K trailer and the front end sits too high when I tow.
Who wants to trade springs? I guess I should confirm which set I have? Spring data in next post.
Old Mar 24, 2015 | 08:00 AM
Mystic_Cobra
My front GAWR is 5940.
My front springs are 5C34-5310-ACD.
Old Mar 25, 2015 | 08:36 AM
Mystic_Cobra
I even have proof!
I wonder why mine is NOT on that list.
