Inline 6 Misfiring
Old Jun 24, 2002 | 11:03 PM
88 Red 150's Avatar
88 Red 150
Inline 6 Misfiring
Hello all just found this board and need some help. I have an 88 F 150 4x4 with the six cylinder. The truck only has 59k miles on it. Lately the truck has been mifiring on cylinder 6. I have changed the plugs, wires, rotor, cap. The plug is getting fire. It got me through a screwdriver, so I feel like it is getting plenty of fire to the cylinder. Anyone have any idea what could be going on here. I am hoping for something that is pretty easy to fix, but I am open to any ideas. If I have left anything out let me know.
Thanks for any help you can give.
Old Jun 24, 2002 | 11:17 PM
nitro94's Avatar
nitro94
Inline 6 Misfiring
If you know that the spark is not causing the problem then that leaves fuel (injector?), or a vacuum leak (hose tapped into that intake runner or intake gasket leak?).
Old Jun 25, 2002 | 07:07 AM
88 Red 150's Avatar
88 Red 150
Inline 6 Misfiring
How hard is it to test or remove an injector. I usually try to do my own work when possible.
Old Jun 25, 2002 | 11:23 PM
nitro94's Avatar
nitro94
Inline 6 Misfiring
The upper intake needs to come off to replace an injector. So if I didn't want to spend a $100 on a guess then you could remove 2 injectors, switch then and see if the problem followed the suspected bad injector.
Old Jun 26, 2002 | 07:19 AM
88 Red 150's Avatar
88 Red 150
Inline 6 Misfiring
To change an injector is it just unplug the electrical and pull the old injector out. How is the injector held in place?
Old Jun 26, 2002 | 07:22 AM
ringkong's Avatar
ringkong
Inline 6 Misfiring
It is held in place by the fuel rail, it will come out of the engine fairly easy, taking it out of the fuel rail is another matter, it is in there pretty tight. DO NOT DAMAGE THE O-RINGS, when you re-install the injector!!! and don't forget to release the fuel pressure before mess with the injectors.
Old Jun 26, 2002 | 10:27 AM
Skoobydu's Avatar
Skoobydu
Post Inline 6 Misfiring
