4x4 swap
Old Oct 22, 2013 | 11:17 AM
bigbrown1985's Avatar
bigbrown1985
4x4 swap
Dose anyone have good pictures of putting a Dana 60 into a 2x4 f250 bump side?
Old Oct 22, 2013 | 01:08 PM
JEFFFAFA's Avatar
JEFFFAFA
I'm confused. A Bump F250 will already have a Dana 60 Rear axle. Unless ofcourse you mean Adding one to the front and making it a 4X4. If you have a donor truck I would put your cab and bed on the donor's frame.
Old Oct 22, 2013 | 04:50 PM
bigbrown1985
I'm converting it to 4x4 and I would have no problem changing chassis except I'm not going to find a crew cab short bed 4x4 around that's affordable or atcall
Old Oct 22, 2013 | 06:19 PM
HIO Silver's Avatar
HIO Silver
A 2WD to 4WD is pretty much a solid axle swap.
To the OP, what system are you looking to do? Three-link or four-link with a panhard bar or leaf springs? Second, what are you going to do with the crossmember... a D60 is not gonna like it being in the way. Third, steering plans? Fourth, shocks mounts?
Old Oct 22, 2013 | 07:13 PM
bigbrown1985
It's getting a 7.3 powerstroke zf5 tranny 10.25 rear 60 front 8 inch lift f250 springs of course custom mounts. Not sure about steering yet and mounting the shocks after!
Old Oct 22, 2013 | 07:33 PM
JEFFFAFA's Avatar
JEFFFAFA
Don't forget transfer case mounting, driveshafts, maybe carrier bearing, hydralic clutch, exhaust, disc brakes, vacuum pump, fuel pump and tank, intercooler,etc.
Lotta Fab work but end result would/will be COOL!
Old Oct 22, 2013 | 08:19 PM
HIO Silver's Avatar
HIO Silver
You'll have more luck Googling for pics. Add hitting up pirate4x4.com for info.
Sources:
Offroad Design - Fullsize Chevy GM 4x4 Suspensions, Parts and Performance
Broncoair.com CURRENT PROJECTS
Trail Gear
Offroad Unlimited
Jasper Offroad
Kelderman.com
Old Oct 22, 2013 | 08:21 PM
bigbrown1985
No inter cooler t case mounts to tranny so no specific mount for that just tranny. Oh and a hydro boost break set up and custom mount for slave cylinder, forest green metallic paint black carpet king ranch seats cab lights dual 5inch mitre cut flat black stacks.
Old Oct 22, 2013 | 08:23 PM
bigbrown1985
16.5 37 inch military tires. Custom winch bumpers custom gauge cluster to be able to use obs powerstroke gauges
Old Oct 22, 2013 | 08:51 PM
BradyCouchman's Avatar
BradyCouchman
Would love o see how this turns out
Old Oct 22, 2013 | 10:01 PM
bigbrown1985
Hopefully great I can't wait myself! Oh best part I got the truck for no cash just my labor haha score for me
Old Oct 22, 2013 | 10:20 PM
crazed87bronco's Avatar
crazed87bronco
If your doing leaf springs in front it will be pretty simple to do seen alot of people do it on these trucks got any pics of the crew cab? Where are you located? I have a brand new set of skyjacker 8" 99-04 super duty leaf springs I want to sell I was going to use them in my 71 crew cab build but thinking of going coil over front now with a 4 link setup. Another bump side diesel conversion hahaha
Old Oct 22, 2013 | 10:33 PM
bigbrown1985
http://s1011.photobucket.com/user/je...in=true&page=0
bigbrown1985
I'm in antelope Sacramento area!
Old Oct 22, 2013 | 10:38 PM
bigbrown1985
It's not just another bump side diesel, because everyone and there moms do a "legendary cummins turbo diesel" now I'm a ford guy to the bone not saying the cummins is bad but I would never and I quote I will never put a cummins or anything besides a ford in a ford no way no how!
