Winch idea
I was taking a break yesterday when the garbage truck came to empty the dumpster. They hooked a cable up to the rear of the dumpster and tipped it up and emptied it into the truck. At first I thought it had a winch on there but it doesn't. On top of the truck is a cable fastened to the rear of the roof. The cable loops around a pully on a hydraulic ram and comes back through a steel guide, and hangs off the back. Retracting the ram loosens the cable and extending it pulls the cable in.
I'm thinking I could make a setup like this under the bed of my truck. I'd only get a pull length of half the length of the ram, but usually that's all that's needed. Multiple rams in opposite directions could increase the distance, or allow front and rear pulling.
Heavy duty winches are expensive but I can get almost any hydraulic parts for nothing.
Any comments or thoughts? Anyone done anything similar?
Just a thought.
Kevin K.
This cyl. from northerntools.com might do. I know they use Prince for a lot of the aftermarket dump bodies.
To pull a stuck pickup truck, for the pulling I think you would need a one inch pin and min. of a three inch tube and 36 inch stroke.
PRINCE Tie Rod Cylinder for Heavy Duty Applications
Tie rod construction, double acting, heavy duty, high strength tie rods. With ground and polished chromed piston rod, cast iron piston with O-ring seals and back up washers, polyurethane rod wiper, cast malleable rod clevis, zinc plated pins and clips. The maximum working PSI is 2500 and bursting PSI is 5000. These name brand cylinders carry a 3 year warranty. Seal kits are available also. The 2in., 3in., 3 1/2in., 4in. and 4 1/2in. bore cylinders have 1/2in. working ports and 1in. pins. One exception is 909708 which has 1 1/4in. pins. The 5in. bore cylinders have 1 1/4in. pins which are included and 3/4in. working ports.
In Stock
Ship Wt. 163.0 lbs
Item# 909548
Discount Price... $379.99
I mean, what's the point in bolting on a winch that'll work perfectly from the start when you can spend days and weeks and twice as much money building a psuedo-winch that probably won't work at all, and if it does, would probably break the first time you use it?
Where's your sense of adventure?
K.
