Do you 'Kit' or Fabricate?
Old Oct 20, 2013 | 02:18 AM
JSchubz's Avatar
JSchubz
I often wonder, should I buy the ready-made kit, or try to fabricate it myself?
I look at the bracket to mount a Toyota box... I could make that.
Front disk brake brackets? Looks pretty basic to me.
Power brake booster and master cylinder mount? I could probably figure that out, too.
Not that I would, but I could maybe (eventually) figure out how to fabricate a dropped front axle.
Machine an engine block from a solid chunk of aluminum? Uh...no
I have more time than money, and a whole garage full of tools. My labor is
'free', I enjoy designing and fabricating, and steel is cheap. Not to mention the pride in doing it myself.
I especially like it when someone sees something I made and asks "Where did you buy that from?"
How about you guys? How many of you make your own parts, versus buying pre-made ones?
Old Oct 20, 2013 | 02:59 AM
AXracer's Avatar
AXracer
I grew up making my own parts and still do. I'm proud of myself when i come up with a clever and/or elegant solution. But I have learned not to "fall in love" with my first effort, but to walk away for a while then come back and say what could be done better, and if it's significant enough I'll scrap the first one and do it over. To me visual as well as functional elegance is equally important.
Old Oct 20, 2013 | 03:44 AM
dynamic's Avatar
dynamic
For me it's often a time x money issue. If I can make the part cheap enough and get the same result. I'll make it. But if I'm going to spend a weekend fabricating an reasonably priced part ill just buy it. Now if it can't be had. Well that I have to make to prove the na Sayers wrong.
Old Oct 20, 2013 | 06:52 AM
Gicknordon's Avatar
Gicknordon
This being my first real ground up project, ive leaned toward more ready made kits. Some ive been happy with and some, like my rear sway bar, i felt like i didnt get a whole lot for the money i paid fo rit and should have just bought the raw materials and made it my self. Now there are other parts i have fabricated out of necessity. Things like my clutch mc mount. I should probably follow what ax said and not get too proud of my first attempt because i do feel like sometimes things can turn out better.
Old Oct 20, 2013 | 08:41 AM
Drewski 2's Avatar
Drewski 2
I also tend fabricate a lot of the parts that are within my capabilities and aren't necessarily available at a reasonable price. I've always loved building things, whether out of wood, fiberglass, or metal, so I always look at whether I can build the part.
And.........being a darksider, I'm usually building something that is not in a catalog.
Old Oct 20, 2013 | 08:51 AM
oldmerc's Avatar
oldmerc
oldmerc
I will often make up my own parts ,jigs ,adaptors , etc because I can , I have the tools and time is really not an issue .
Old Oct 20, 2013 | 09:04 AM
ChuckRob's Avatar
ChuckRob
I do a combination of both. If I find a kit or part that is reasonably priced and of good quality I will go that way, if not I will make it.
Old Oct 20, 2013 | 09:42 AM
oldmerc's Avatar
oldmerc
oldmerc
I will qualify my last post with ( If I can) because there are lots of things that I simply cannot do . After re-reading that post it sounded to me like I was bragging .
Old Oct 20, 2013 | 10:51 AM
Project-55's Avatar
Project-55
I started my current project with the mind set that "I was going to build it" from beginning to bitter end, hehe.
Like so many others here, I enjoy fabricating and the mental gyrations that go along with it.
So far I have bought no kits, only the steel needed to make what I want.
Old Oct 20, 2013 | 11:06 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I do a combination of both. Sometimes I fabricate parts, sometimes I'll buy them.
I know I could easily have fabricated my own wiring harness. I ended up buying a premade one because after I would have bought all the different colors of wires needed it was about the same money as buying the pre-assembled harness.
Sometimes I fabricate parts just to learn how to do something, or to try doing something that I haven't done before. My whole truck project is a big learning experience. Sometimes I fabricate parts because I'm flat broke (or just a major tightwad cheapskate) and can't see spending the big bucks.
I do get a lot of satisfaction from building and/or modifying something to work. More so than if I opened my checkbook and a catalog and bought a part.
Its all good
Bobby
Old Oct 20, 2013 | 05:24 PM
gdub's Avatar
gdub
I've fabricated most things on mine. I'm too cheap to do anything else. I did buy a wiring harness and new gauges though.
Old Oct 20, 2013 | 05:31 PM
ZOOT's Avatar
ZOOT
Combo of both for me too. Usually when I fabricate, it's the third try works the best. The first is like a prototype, the second is almost there, the third is the final fit. Its good to push your skills. If you can't make it, buy it.
Old Oct 20, 2013 | 08:52 PM
GB SISSON's Avatar
GB SISSON
I've fabricated a couple of stories to family members when I'm heading out to buy another old beat up truck....
Old Oct 20, 2013 | 10:04 PM
tinman52's Avatar
tinman52
Welder User
Much more enjoyable to me to build what I need, but sometimes much quicker to buy it (if possible). Problem I have had with many of the "parts" available is the quality is poor....so I end up improvising.
Old Oct 21, 2013 | 01:29 AM
Mervy49's Avatar
Mervy49
I think making things like brackets is were the fun is in putting these trucks together. I looked through countless catalogues and drooled at the shiny expensive doodads and stuff that seemed necessary, I found more enjoyment in duplicating some of the simpler things.
