White smoke pouring out
I have a 2008 Ford 250 diesel that is pouring out white smoke from the exhaust when it goes into "cleaning filter" mode. I really don't understand this because I have a dpf delete with a sct tuner. I thought with the tuner and delete the truck wouldn't go into filter cleaning mode . I contacted Ford and they said it was normal for white smoke to come from the exhaust during this process. Any idea what's going on maybe tuner is bad?
you need to remove the tuner, put the exhaust back to stock. Then make sure it is running right.
Then you need to consult your tuner manufactor to find out its functions.
Dpf installed in truck or not.
If you allow it to regen with no dpf in place all your doing dumping fuel into the exhaust.
ptc3
Computer Chips & Tuners
08-01-2006 04:22 PM
