1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
White smoke pouring out
Old 10-19-2013, 09:35 AM
Nic High's Avatar
Nic High
Nic High is offline
I have a 2008 Ford 250 diesel that is pouring out white smoke from the exhaust when it goes into "cleaning filter" mode. I really don't understand this because I have a dpf delete with a sct tuner. I thought with the tuner and delete the truck wouldn't go into filter cleaning mode . I contacted Ford and they said it was normal for white smoke to come from the exhaust during this process. Any idea what's going on maybe tuner is bad?
Old 10-19-2013, 12:41 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
Your tuner didn't shut off regens. Do you have custom tunes?
Old 10-19-2013, 12:51 PM
Iggy2867's Avatar
Iggy2867
Iggy2867 is offline
When it happened to my truck it was an O ring on the turbo leaking oil into the engine block. Ford had my truck for a month trying to figure it out. Fun times.
Old 10-19-2013, 03:01 PM
Nic High's Avatar
Nic High
Nic High is offline
My tuner hasn't turned off regens. The tuner is set up with the dpf delete on.
Old 10-19-2013, 06:30 PM
senix's Avatar
senix
senix is offline
Received 1,428 Likes on 1,021 Posts
you need to remove the tuner, put the exhaust back to stock. Then make sure it is running right.
Then you need to consult your tuner manufactor to find out its functions.
Dpf installed in truck or not.
If you allow it to regen with no dpf in place all your doing dumping fuel into the exhaust.
Old 10-19-2013, 08:52 PM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
Reread your tuner instructions or go to the SCT forum, something isn't set up right, if your truck is going into regen your tuner isn't working.
powerstroker88
07-01-2007 04:31 PM
ptc3
Computer Chips & Tuners
08-01-2006 04:22 PM
Quick Reply: White smoke pouring out
