Craigslist find of the week!
#904
And some more.
https://springfield.craigslist.org/cto/5161977548.html
https://springfield.craigslist.org/cto/5154444033.html
https://springfield.craigslist.org/cto/5121626942.html
Fummings....1978 f-250 12 valve cummins
https://springfield.craigslist.org/cto/5120175412.html
https://springfield.craigslist.org/cto/5160258566.html
1976 Ford Mud Truck
1976 Ford Mud Truck
#905
I know you guys opinions on modern wheels on vintage trucks, but this thing is truly sweet...
1979 Ford f250 4x4
1979 Ford f250 4x4
#907
Yep you're correct. But there are some deals out there as well. I come across them from time to time myself. You just have to look around.
#908
#909
I have a question for you guys: There are many common abbreviations that people use in advertisements for their vehicles, such as "OBO" for "or best offer." Every now and then I'll see the abbreviation "JKS" in an advertisement, and I have no idea what that means. Here is an example: 78 F250 4X4 jks Can somebody tell me what "JKS" stands for?
#910
I have a question for you guys: There are many common abbreviations that people use in advertisements for their vehicles, such as "OBO" for "or best offer." Every now and then I'll the abbreviation "JKS" in an advertisement, and I have no idea what that means. Here is an example: 78 F250 4X4 jks Can somebody tell me what "JKS" stands for?
Jason
#911
Here's a few more things that haven't yet been mentioned. The grille shell is bent just inside the F letter and has a dent on the drivers side where it mounts to the fender. The grille insert is warped on the driver side just above the headlight. The body side moulding is missing on the passenger side cab corner. The driver side inner fender panel is crushed with a poor attempt to semi straighten. Notice the kinks and low spots where it mounts to the fender just behind where the aux bettery tray would sit. And the huge crush point right about where the hood hinge mounts. Then there is the ( I can't believe that Rich didn't pick this one out) body lift. No one caught the hockey pucks (so to speak) mounted on top of the rubber isolators. And the last big deal item to cause everyone to run away from this truck is the missing FMVSC sticker from the driver side lock post. I just wonder ho bad the inside of the bed looks on this beast.
[QUOTE=FordMan007;15555518]The electrical tape job is awesome under the hood.
[QUOTE]
I'm not saying it's bad but my uncle use to do a lot better.
Some sucker will buy that baby and be REALLY disappointed when it gets delivered half way across the U.S.
WTF WTF!?!?!?!? LOL, before buying anything used look at every detail of it.
It doesn't even have power steering? At least I don't see a pump on the engine??
The electrical tape job is awesome under the hood. You can tell the motor hasn't seen fresh paint in years (except valve covers). Some sucker will buy that baby and be REALLY disappointed when it gets delivered half way across the US.
X2 on the dash pad, and factory oil pressure and gas gauge inop. See in the video right before the test drive, the passenger side of the bed below the side marker light has 3 open holes, probably from the Ranger badge? 13,500 and holes in the bed and a crummy dash pad, aw come on man.
Interior colors are off, 4 spf shift know and xfer case **** goofy looking. Pedal covers....FAIL. Aftermarket fender lip liners FAIL.
6:37 Passenger side park light out. Antenna is wack angle. X2 on the wrong year mirrors and mounted wrong and the dash bezel and glove box liner are miss matched.
Cool tunes during the drive, I want to hear the engine and exhaust. I got tired of looking. X2 on all that stated and at least straighten the cross member before you paint it for 13.500. lol
thats a 4 grand truck. dash surround is painted black still has the wood grain around the glove box. none of the stock gauges work. wrong year of mirrors and they are mounted wrong. interior is all screwed up. door panels dont match. dashpad is cracked and sun faded. no door sill plates just some homemade alum. tread plate. wheres the gas go? never seen a front driveshaft like that in any of the 5 "highboy" trucks i have owned. i see lots and lots of rattle can black. front cross member is all bent to hell. but many are. wonder if the kept the vin true if they swapped cabs? cheap military take offs that are bias ply. anything else i miss?
The reason for my post is to show what a good ad will do for you......hence the current 16 bids with the top bid at $15k and going up.
