compression
Old Oct 15, 2013 | 02:44 AM
Mr Moe's Avatar
Mr Moe
Question compression
I just did a compression test on my 1989 2.9 v6 with 257,000 miles on it. I got readings from 158 to 150. What I don't know is what a new motor would read. I understand their shouldn't be more than a 30% difference between cylinders and I believe I am good in that aspect. I guess what I need to know is what have I learned from the test? How should I interpret the readings? :
Old Oct 18, 2013 | 05:59 PM
xlt4wd90's Avatar
xlt4wd90
I think your readings indicate that all the cylinders are in pretty much the same condition; none of them is much more worn than any of the others. To get more detailed information, you would need to do a leak-down test. This will tell how worn the rings and valves are. But if you're not burning oil excessively, I wouldn't worry about it.
To properly lubricate the cylinder walls, some oil will be consumed during normal operations. Ford says that up to 1 quart burned every 1500 miles is "normal". That seems kind of high to me, but it's what my 87 Mustang v8 has been doing since new.
Chisum5013
Feb 4, 2016 01:14 AM
RANGER589
Sep 3, 2010 10:02 AM
TheNomad
Jun 18, 2008 08:35 PM
rowdie-stang
1997 - 2003 F150
Feb 17, 2006 10:34 PM
woodranger
1983 - 2012 Ranger & B-Series
Apr 30, 2004 08:10 PM
