Loading without radiator
Old Oct 12, 2013 | 06:22 PM
FordYoungGun35's Avatar
FordYoungGun35
Going to be loading truck in sig onto a trailer.The radiator is off so everytime it runs tranny fluid gushes from the tranny lines that hook into the radiator. My concern is the tranny getting to low on fluid and not being able to drive uo on the trailer and me burning something up. Do you guys think i'll be okay or should I put the radiator in hook up the hoses and lines, and fill it with coolant and fluids?
Old Oct 12, 2013 | 06:30 PM
Evan_P's Avatar
Evan_P
Push it on the trailer. Don't run it with the trans gushing fluid. You don't want to run the trans low on fluid.
Diesel_Brad's Avatar
Diesel_Brad
Slide the fittings back and use a piece of hose to connect the to steel lines
Old Oct 12, 2013 | 06:41 PM
bashby's Avatar
bashby
Yep, just loop the lines together with a piece of hose.
Old Oct 13, 2013 | 05:41 AM
tjc transport's Avatar
tjc transport
i ain't rite
hook the cooler hoses together with a piece of hose as said by others, don't run it too long to heat things up, and you will be fine..
Old Oct 13, 2013 | 11:42 PM
FordYoungGun35
so put a hose connecting the 2 tranny coolant lines?
Old Oct 13, 2013 | 11:55 PM
cbrown9064's Avatar
cbrown9064
Yep...that's what the others are saying...
Old Oct 14, 2013 | 01:16 PM
FordYoungGun35
should one of the lines becoming from the transmission oil cooler that's infront of the ac condenser?
comsupany
May 3, 2016 07:30 AM
black_sport
Sep 19, 2012 07:53 PM
bigenough
18
Jan 22, 2010 08:35 PM
akpilz2004
1978 - 1996 Big Bronco
Feb 12, 2005 01:44 PM
Zowski
Jan 30, 2004 06:18 PM
