Zero-Rust Prep-Step
Old Jun 19, 2003 | 02:28 PM
j gibbs's Avatar
j gibbs
Zero-Rust Prep-Step
Has anyone used the ZR brand Prep-Step instead of Jasco, Ospho, or another similar product?
It seems that using products made by the same company and designed to work together should be the best combination. That could just be my consumer philosophy though. Any opinions on what works best?
Does anyone know how Prep-Step takes to sandblasted metal? Cid pointed out this consideration in an earlier thread.
Old Jun 19, 2003 | 07:59 PM
Aekisu's Avatar
Aekisu
Zero-Rust Prep-Step
Haven't used it myself but here is the official web link:
Zero Rust Prep-Step
I noted a comment on sandblasted material
Old Jun 19, 2003 | 08:13 PM
Aekisu's Avatar
Aekisu
Zero-Rust Prep-Step
I also found this on the Zero Rust web site.
Prep-Step is not an acid, i.e., not a converter. Prep-Step is a totally biodegradable, environmentally friendly product that is helping solve many long term protection problems.
Old Jun 19, 2003 | 09:06 PM
286merc's Avatar
286merc
Zero-Rust Prep-Step
Its primary purpose is to soften thick scale that can then be scraped off. If you are going to sandblast it may not be required unless the build-up is thick and nasty.
I'm a ZR distributor and have only had a few calls for it in several years.
Old Jun 22, 2003 | 02:34 PM
j gibbs's Avatar
j gibbs
Zero-Rust Prep-Step
From what I have read on the web-site it sounds like it can be used just like Jasco. If you do use it on scale and then scrape it off it says to reaply prep-step. It seams that at about $10 for a 1.5 lb bag that is mixed with water, 2 tablespoons/gallon, it is cheaper than Jasco at $5/quart. If it works even better with ZR it sounds like a win-win product.
Carl, being a dealer maybe you can shed some light on something for me: Why is there zerorust.com and zero-rust.com?
Thanks
madscientist
Jul 29, 2015 01:25 AM
WhiteEx
2015 - 2020 F150
Jun 9, 2015 06:16 AM
KenEdwards
Apr 20, 2015 11:23 AM
Coachmen320
Apr 12, 2015 03:20 PM
Uni Moe
Mar 6, 2015 07:19 PM
