Drain Pet*****?
Old Oct 9, 2013 | 07:45 PM
MontanaboyDesigns's Avatar
MontanaboyDesigns
Drain Pet*****?
So I just went out to the rig and all my fluid had dumped out of my radiator onto the street.
I found it was coming out of the little drain valve and after messing with it with a wrench and getting it all over me, I think it might be stripped or something.
Can you just blow these things out or what's the story? Should I pull it and replace it, or is there a better part to get? Any help would be great!
Old Oct 10, 2013 | 06:53 AM
JWA's Avatar
JWA
Its helpful to include more info on your truck or car----kinda hard to tell, just WAG's otherwise.
Assuming you have some sort of truck here's the drain I think you mention:
This is a plastic part most likely threaded into the radiators plastic bottom tank---if someone hasn't over tightened it recent its quite possible it has just cracked. The above photo shows mine had sheered off but thankfully it has provisions to fit an Allen wrench inside it.
NAPA or Ford should have the correct replacement part.
Hope this is helpful.
Old Oct 10, 2013 | 11:31 AM
MontanaboyDesigns
Thanks! And yeah, I left out the rig like a moron. I have a 73 F250, and it was the little drain petcock. I stripped the bolt, and then fluid went everywhere but we had a pan, so it wasn't too messy. So new fluid in. My mechanic that has been helping me with a lot of this stuff keeps telling me that I am going to be running into this stuff until I get her dialed(she's new to me, just on the road). 40 year old truck, so hopefully at some point I'll get her to where I can not worry so much. Yeah right. Anyways, thanks for the tips, JWA!
Rob89
6.2L V8
Jun 22, 2019 03:52 PM
Nightrain
1983 - 2012 Ranger & B-Series
131
Mar 3, 2019 03:55 PM
Subzero68
Oct 18, 2014 09:56 AM
TurboMonkey
1997 - 2003 F150
19
Aug 1, 2005 06:38 AM
locknut550
Jan 9, 2003 08:51 AM
