Random stuff
Old 02-14-2014, 01:18 PM
husker's Avatar
husker
husker is offline
Smart phone and Navbar...... Does anyone else use a android or iphone to check in here on a regular basis. Mine phone just automatically switched to the Navbar when I log in and it is crappy. I don't like it at all.
  #137
Old 02-16-2014, 07:54 AM
Flip4ford's Avatar
Flip4ford
Flip4ford is offline
sorry I tried once didn't go well so I use computer
  #138
Old 02-16-2014, 08:12 AM
itsabullitt's Avatar
itsabullitt
itsabullitt is offline
On my windows phone now and it seems ok for replies to threads. Having to go searching
through the forums could be difficult.
  #139
Old 02-16-2014, 09:10 AM
Garden Spyder's Avatar
Garden Spyder
Garden Spyder is offline
I do it when I have FTE withdrawls, and need an FTE fix. its cumbersome but not too bad.
  #140
Old 02-16-2014, 09:18 AM
husker's Avatar
husker
husker is offline
The previous form was a lot easier to use. This one is more jumbled and may have more options, but is a bit of a pain.
  #141
Old 02-18-2014, 05:25 PM
ProjectDually's Avatar
ProjectDually
ProjectDually is offline
Android, and I'll view the forums, but posting is weird. Sometimes it just doesn't reply, or type right for some reason. So I'll just view the forums best I can when I am working, or when I know I'll not be at a computer for a couple months.
  #142
Old 02-25-2014, 06:39 AM
Flip4ford's Avatar
Flip4ford
Good Morning--- Soooooo If you had a full width dana 44 (for free) what Gears/axles and lockers would you want to put in it?
  #143
Old 02-25-2014, 06:44 AM
Garden Spyder
That depends on what its going into and what I would be using it for.
  #144
Old 02-25-2014, 07:04 AM
74 bronco's Avatar
74 bronco
74 bronco is offline
Driver side drop or passenger? high or low pinion? Standard or reverse rotation? 1/2 or 3/4 ton? oem axles or chromoly axles? leaf or coil spring or coil over or nitergen shock? Regular tie rod or ram asst steering? Front or Rear axle? 4 or 3 link?
  #145
Old 02-25-2014, 07:36 AM
husker's Avatar
husker
husker is offline
Did you forget anything Clint? Good questions.
  #146
Old 02-25-2014, 10:22 AM
Flip4ford's Avatar
Flip4ford
Driver side drop-- high pinion- Reverse rotation- oem axles coil springs or Regular tie rod -- Front axle-- 2 link track bar-- Weld on C mounts not solid. I do not know if it is 1/2 or heavy half or 3/4 ton. :-) I don't know if it has disk or drum but I am betting drum.
  #147
Old 02-25-2014, 11:34 AM
HappyJack's Avatar
HappyJack
HappyJack is offline
Well gears pends on what size tire and what trans/t-case you are gonna use. Lockers pends on what 4x4 system and what ya use it for. Axles pends one them first things an how hard ya play.
  #148
Old 02-26-2014, 05:33 AM
74 bronco's Avatar
74 bronco
What rear axle you using and what gear ratio is it? How much money do you to build it?
If money is there I would do chromly axles,selctable locker if driven on street, gears wold depend on what gears are in rearend and if need to change for bigger tires.
  #149
Old 03-03-2014, 06:34 AM
Flip4ford's Avatar
Flip4ford
Anyone need Novalog 70/30 quick pens-- Doc's office sent in the wrong script- insurance company won't take them back or refund- so I am out $350-- I would like to help someone out, instead of tossing them.
  #150
Old 03-03-2014, 02:50 PM
HappyJack's Avatar
HappyJack
I have a co worker who is interested. Let me know.
Quick Reply: Random stuff
