Sponsored by: Auxito
Can anyone help?
Old Oct 9, 2013 | 01:00 AM
Nitropeewee's Avatar
Nitropeewee
Question Can anyone help?
I'm trying to install a new 8' plow on my 2002 F-150 w/ extended cab, short bed 4X4 w/ 5.4 V-8... I have a 3600 GVW front end and need a 4200 GVW to get the plow I want. Was told that getting bigger torsion bars would work but Ford discontinued them and can't find anything online. What can I do? Any ideas would help and thank you!
Old Oct 12, 2013 | 02:34 AM
Bluegrass 7's Avatar
Bluegrass 7
Research the use of aux air springs.
Good luck.
Old Oct 12, 2013 | 09:00 AM
danskool's Avatar
danskool
Go Bills !
i put Gabriel HIJACKER Shocks on the front of my jeep, (air shocks) Onboard mini air compressor. I would hook up plow and flip switch to get 80 psi. When i unhooked plow. I flipped the valve in the cab to lower pressure back down to 15psi.
I recently put a 'sno-way" plow on my f150(sold jeep).. she is Untested at this point but If i need a bit more boost.(snowways are light so i might not) I will be doing the same and putting air shocks on it with another onboard mini compressor. it is a good way to get a little bit of temporary lift power and not suffer ride the rest of the year
Old Oct 12, 2013 | 09:20 AM
danskool's Avatar
danskool
Go Bills !
Ok, Now you did it.. I was thinking, I just put new tires on the truck, Big beefy ones for snow and i scrub every once in a blue moon in the right circumstances.. I better check the plow again to make sure i am ok without the Hijackers. I aint got time for scrubs.. There is money to be made son. Had my jeep wrangler for 5 years 97. That thing paid for itself and parts 10x over from plowing..
Might you consider a sno-way? it is lighter and it takes a beating well.
danskool
1997 - 2003 F150
Nov 28, 2012 11:30 AM
dylanellis
36
Dec 18, 2011 06:14 PM
Mr. Finch
Nov 26, 2009 08:07 PM
Greg250
Oct 11, 2003 04:44 PM
Chad Winship
1978 - 1996 Big Bronco
Dec 1, 2002 03:08 PM
