propane injection?
Old Oct 8, 2013 | 06:37 PM
79sparky's Avatar
79sparky
propane injection?
Is propane injection a ligament thing? From what I heard about it it sounds great just not sure if my friend that told Mr about it is pulling my leg or not. Thanks
Old Oct 8, 2013 | 07:33 PM
88 Ford IDI's Avatar
88 Ford IDI
Propane injection will add some power but most are scared to run it in an idi due to the possibility of detonation. From what I have read though detonation usually occurs when someone adds too much propane too early. If you do run it, you would want it to come on at higher boost levels and higher in the rpm band as well. This makes detonation less likely while running it.
Old Oct 8, 2013 | 07:48 PM
79sparky's Avatar
79sparky
Right I was thinking around 10 psi which is also higher in the rpm range when I reach such boost so it will cover 10 psi to 14 psi max when I'm touring. I have heard about the detonation which is why I'm asking how much propane should be added. I'd prefer to stay on the leaner side of the propane stone I don't think I really need to add a whole lot.
Old Oct 8, 2013 | 11:51 PM
RacinNdrummin's Avatar
RacinNdrummin
Why not just turn your pump up?
Old Oct 9, 2013 | 04:52 AM
79sparky's Avatar
79sparky
It is up and as tight as the adjustment save is I believe it is up all the way just seems when I get up to 12 to 14 psi it can' give out the proper amount of fuel for all the air
quality1construction
13
Jan 18, 2012 03:20 PM
Elderstarr
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Dec 18, 2006 06:46 AM
Trail Rider II
Bio-diesel, Propane & Alternative Diesel Engine Fuels
87
Jun 7, 2004 03:02 AM
bigdieseldav
May 21, 2004 05:48 PM
67 428 Fairlane Ranchero
Mar 18, 2003 05:04 AM
