1978 - 1996 Big Bronco
Engine build advise
Old Dec 30, 2013 | 11:28 PM
nandomart's Avatar
nandomart
Still working on this...and i have a question..
While my engine is getting built..I started a zf5 swap, saginaw install and potentially a maf swap. I searched and didn't not find my scenario so I hope you dont mind me asking.
I removed the maf engine harness, engine bay harness, intake box with tube and eec off of a 95 f-150 with a 4rw70. My question is being that I am doing a zf5 swap what repining needs to be done to the 4rw70 harness? will this harness still work for the intended maf swap?
Old Dec 31, 2013 | 10:35 AM
Kemicalburns's Avatar
Kemicalburns
not sure that you will need to do much of anything. the zf is a manual trans while the 4r70w is a computer controlled auto trans. I suspect the harness will work just fine.
unless of course you can find an 94 bronco, with a 5.0 running MAF. this was the first year making the harness a little more plug n play. regardless the computers will throw a no trans detected code, engine should still run correctly. a computer tune could possibly turn that stuff off as well.
Old Dec 31, 2013 | 10:36 AM
Conanski's Avatar
Conanski
Originally Posted by nandomart
Would I be able to use on of these cams with the parts I currently have? If so would the 35-349-8 be the best choice? What I would like to do is not have to go back into the engine again.
Those Extreme Energy cams are going to push engine fueling requirements well beyond what the stock EFI and fuel systems can cope with so like it or not I think you're better off not doing a cam at this time. The truck will need MAF, larger injectors and fuel pump/s and a tuner once the cam is changed.
P.S. DesktopDyno says this motor will make 275-280hp with the stock cam which is gonna stretch the stock injectors for all they're worth, but it's a 400hp motor with the 35-349-8.
Old Jan 1, 2014 | 02:03 PM
nandomart's Avatar
nandomart
should i swap out the complete harness including the head light harness and engine harness from the bronco with the 95 f150 maf harness?
also the f150 was not 4x4 are there any changes i need to make? If its easier i can use a manual transfer case out of a 97 f250 parts truck i have.
Pat54632
43
Mar 12, 2017 12:59 PM
Redneckfordf2502002
Apr 6, 2016 11:10 AM
boomer1ny
15
Dec 13, 2013 10:20 PM
CLIFF1989
Mar 7, 2010 04:51 PM
85camaroman
Mar 19, 2008 09:59 PM
