Need Help
Old Oct 7, 2013 | 07:45 PM
Mishlerdennis's Avatar
Mishlerdennis
Exclamation Need Help
I have a 97 Expedition XLT 5.4L and even on first starts of the morning my temp gage is maxed out hot, I replaced the thermostat today and it had no effect.. What is doing this? I can even feel the engine and it can be 50degrees in the morning and the truck will still read out that it is overheating. I know its not a cracked head or block because it would read normal if not cold before started and only overheat after it has ran for a second. Could this be a sensor? and if it is how do I replace it?.
Old Oct 8, 2013 | 12:13 PM
Torklift Sheryl's Avatar
Torklift Sheryl
SPONSOR
Welcome to the site! I hope you'll find good info here for your problem soon.
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Old Oct 8, 2013 | 02:05 PM
Mishlerdennis
Fixed
Its the water temp sensor, now i just need to find it and replace it asap
Old Oct 11, 2013 | 03:27 PM
Encho's Avatar
Encho
The Southernmost Mod
Hey Dennis, I'm sorry I didn't catch this earlier, I would have moved it somewhere where you could find more help, anyway I'll be moving this to the Expy chapter, oh, and welcome to FTE! have fun!.
Old Oct 11, 2013 | 09:24 PM
Mishlerdennis
Exclamation Wiring maybe?
Ive replaced the thermostat and the temp sending unit with no avail, Im still reading overheated all the time but the engine is usually at normal operating temp 180-195 so what in the world could this be?
Old Oct 11, 2013 | 09:52 PM
Encho's Avatar
Encho
It's probably a bad sending unit giving a wrong signal, but just for good measure you could check the head gasket and the coolant and engine oil, if there seems to be any mixed with the other that should point at a blown head gasket, are you losing any coolant?.
Old Oct 12, 2013 | 10:02 PM
Mishlerdennis
There is no oil or water being consumed by the truck, and they are still what they are supposed to be oil is pure and antifreeze is pure.. Maybe its a wiring issue?
Old Oct 13, 2013 | 01:12 PM
5.4T's Avatar
5.4T
Could have an air pocket in your cooling system, Turn it on when its cold with the cap off for 5-10 min hopefully that solves it.
Old Oct 13, 2013 | 02:09 PM
Mishlerdennis
I have burped the cooling system, Replaced the thermostat, replaced the water temp sensor, checked the oil and coolant which are both still pure, have great compression.. Any other ideas are more than welcome and a thank you to 5.4T for the cooling system burping idea.
Old Oct 13, 2013 | 06:46 PM
5.4T's Avatar
5.4T
maybe a bad cluster? My moms Nissan frontier doing the same thing and just like you I replaced everything.............so that's the only option I got but maybe its the same for you?
Old Oct 13, 2013 | 07:29 PM
DPorter's Avatar
DPorter
How about wire chaffing grounding to the block. Check the harness from the temp sensor closely.
Old Oct 14, 2013 | 12:36 AM
Mishlerdennis
Checking both in the morning, Thanks for the ideas porter and 5.4T
Old Oct 14, 2013 | 08:05 AM
Encho's Avatar
Encho
What about a bad fan clutch? , try to turn the fan by hand, if it offers little resistance then it's time to replace it.
Old Oct 14, 2013 | 10:53 AM
Mishlerdennis
im not understanding how a fan clutch can cause a false reading on the water temp gauge... The fans work fine, even if it is 39outside and the truck has been sitting all night, before its started but with the ignition in the on position the gauge maxxes out immediately without the engine even running
Old Oct 14, 2013 | 11:11 AM
Encho's Avatar
Encho
Maybe it's not a false reading and the temperature is rising up because the fan clutch isn't working like it should (they lose their efectiveness overtime), has it ever been replaced?.
