Sponsored by: Real Truck
Got a grille question
Old Oct 7, 2013 | 03:06 PM
mrsvegan's Avatar
mrsvegan
When picking out a new grille. Is it important to take in to consideration the design and how much or little it restricts air flow?
Old Oct 7, 2013 | 03:41 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
It depends. Do you tow a lot?
Do you live where it it 110* year around or in Alaska?
Most grilles are fine unless they are very poorly made.
Old Oct 7, 2013 | 03:46 PM
mrsvegan's Avatar
mrsvegan
Do not tow much and live in GA.
Old Oct 9, 2013 | 09:46 AM
bikerman2299's Avatar
bikerman2299
This is what I have on mine.
http://www.cwgrilles.com/Merchant2/g...0001/44801.jpg
I haven't seen any kind of temp increases towing or not.
Old Oct 9, 2013 | 09:48 AM
mrsvegan's Avatar
mrsvegan
That's a nice grille. Thank you for your reply.
Old Oct 9, 2013 | 02:35 PM
Km1210's Avatar
Km1210
What kind of grill are you looking for?
Old Oct 9, 2013 | 02:46 PM
mrsvegan's Avatar
mrsvegan
Something nice other than the square hole stock one that came on my ex. I would be very happy to get black but there are a lot of chrome ones I like too.
Old Oct 10, 2013 | 10:49 PM
bikerman2299
Oh by the by, the carriage works grill I bought..... Everywhere I looked said it would mount up perfectly fine, but it didn't. The actual grill itself, perfect! All the welds looked great, nothing was bent or tweaked, awesome.
Then came the mounting part. The bottom mounted up just fine like the instructions said. The top was a different story completely. I had to straighten out the 4 brackets they sent, and 'adjust' them to where the would even touch the grill shell. But after some time with a dead blow hammer, a vice, and an anvil, they lined up just fine. I did have to cut some new slots in the grill shell to slide the c-clips into. Other than that, it was an easy install. Just took a bit of outside the box thinking.
Old Oct 10, 2013 | 11:57 PM
EXv10's Avatar
EXv10
I really don't think so, it's a matter of how many square inches of open space is needed in a worst case scenario and I doubt if any grills on the market even come close to being too restrictive for the cooling.
Old Oct 11, 2013 | 12:03 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
to be honest, the intake draws air from behind the headlight and the side-most portion of the grille.
if you do the Zoodad mod, then a aftermarket grille may have an effect on airflow.
stock header panel. see the small rectangular hole
after the zoodad mod. much larger hole...but even with a restrictive grille, you will still get plenty of air from behind the headlight. you can see the filter element through the bigger hole now
Old Oct 11, 2013 | 08:09 AM
mrsvegan's Avatar
mrsvegan
Very helpful guys! Thank you all for answering.
Old Oct 11, 2013 | 09:32 AM
brmccolley's Avatar
brmccolley
I didn't have any problems with my aftermarket grill (see gallery)
I did have to do a bit of cutting on the OEM surround, but the grill went in without issue.
Ford Truck Enthusiasts Forums - brmccolley's Album: Garage - King Ranch
Old Oct 11, 2013 | 11:19 AM
EXv10's Avatar
EXv10
If you notice the flaps on the grills of trucks in cold weather they have to cover almost 100% to get it to heat up more.
Old Oct 11, 2013 | 04:13 PM
majkthreads's Avatar
majkthreads
I have the same one but in black. I live in GA and have towed here allot. No noticeable temp increase even during the dead of summer.
Your fine with whatever grill you choose.
Spydycarnge
Appearance & Dress-Up
Dec 28, 2009 06:52 PM
Gage2502
Jun 9, 2007 03:35 PM
jetmagnum
Jul 6, 2006 02:22 PM
TKAT79
1997 - 2003 F150
Apr 24, 2006 04:13 PM
rack04
2004 - 2008 F150
Nov 24, 2004 04:53 PM
