Rough idle
Old Oct 3, 2013 | 12:35 AM
ford557SCJ's Avatar
ford557SCJ
Rough idle
Hello guys, to make a long story short, An injector stuck open on my 05 5.4 and bent a rod. I had a new rod put in and all new revisedMotorccraft injectors. This was about a month ago. Truck has ran great for the past 3 weeks until today I put it in park and it idles real rough, put it in gear and it smooth as butter again? (Once in a rare while it will continue to idle rough in gear for a few seconds but then clears up.) New motorcraft plugs were put in right before it bent the rod. The truck runs real strong other wise. I am about done with ford this pickup has been the biggest pile I've ever owned one thing after another and just when I think its fixed its some other stupid problem. I will be giving it a good lookover on Friday but you guys have any ideas? Il start by cleaning the maf and throttle body. Could it be a bad coil? Thanks
Old Oct 3, 2013 | 12:55 AM
Cubawashere's Avatar
Cubawashere
I would check for codes. Check engine may not be on but you may be lucky enough to have a "pending" code and lead you in the right direction... BTW you can usually get a chain auto parts store to check it for free (Advance or Autozone)...read the scanner yourself or they can print out whatever codes.
Old Oct 4, 2013 | 11:02 PM
ford557SCJ's Avatar
ford557SCJ
Well I cleaned the maf and tb and no change, bummer. I'm gona have a buddy look at it on monday
Old Oct 4, 2013 | 11:47 PM
Cubawashere
did you go check for trouble codes? buddy system may be a good idea too but after making sure you have no codes that may facilitate in finding the issue
eallanboggs
1997 - 2003 F150
Oct 30, 2018 10:29 PM
gassplant
2004 - 2008 F150
Jan 25, 2014 01:01 PM
ford557SCJ
Modular V8 (4.6L, 5.4L)
Oct 3, 2013 05:36 AM
first6.9
Jul 24, 2007 09:44 PM
vfrrick
Feb 9, 2006 06:58 PM
