EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
Why limited to 100 mph?
Old Dec 21, 2013 | 11:24 AM
BuzzLOL's Avatar
BuzzLOL
. Liability may be another reason... kill somebody going too fast and deep pockets like Ford's get sued... even if not at fault... Ford got burned good in court on the Pinto fiasco... it's a waste of time and effort to sue anybody with no money... GM was fined over $100Million for 1 exploding gas tank after juries discovered Ford had decided that $1Million jury decisions for deaths in Pintos were an acceptable risk... cheaper than re-designing/recalling Pintos... which was revealed in Ford documents by a whistleblowing engineer...
. UnSpeedRated tires only good to 92 MPH...
. Canada and USA have different regulations on what vehicles are limited to what speeds...
. My '78 F150 SuperCab 4WD full size 8' bed truck w/ snowplow is limited to 75 MPH by the weak 351M engine... the brakes are even more pathetic...
Old Dec 23, 2013 | 03:14 PM
iggybob44's Avatar
iggybob44
Originally Posted by gilchris
I understand and am OK with the F-150 EB being electronically limited to 100 mph. But, beyond the safety aspects, WHY has Ford done this? There must be other reasons as this truck with other engines is not limited. I've never had a vehicle with a speed limiter and I'm dying to know why. 100 mph is plenty fast but I want the REAL reasons. Heat buildup? What? What!?
Well, let me see.........HEAT BUILDUP at speeds over 100 mph would be a "safety" issue, whether you realize it or not.......Perhaps this engine has the ability to far exceed other components of the truck. May i respectfully suggest you direct this question to Ford's CEO, and if you arent satisfied with his answer, get a few friends together and buy a majority stake in the corporation via purchasing 51% of common stock, then you get to design the truck as you would see fit.........LOL
Old Jan 12, 2014 | 10:35 AM
vloney's Avatar
vloney
Ever see a NASCAR race where a car gets airborn? Aerodynamics come into play after a certain speed. Hood pops open over 100? Sue Ford for a poorly designed latch. Ever drove one at speed and it felt like it was "floating"? Wonder how far away you were from that airborn thing I was talking about? A truck is as aerodynamic as a brick. That was a consideration NASCAR had before having truck races at Daytona and Talladega. They had to "adjust" the aero for all of them to keep them on the ground.
Old Jan 12, 2014 | 06:42 PM
ljutic ss's Avatar
ljutic ss
I wonder if the guys with the late F 150's that are supercharged and run 115+ mph in the 1/4 know about hoods popping open?
Old Feb 25, 2014 | 11:46 PM
clem1226's Avatar
clem1226
Or the guy that drives in to a sixty mile an hour head wind at sixty miles an hour.......
Old Feb 26, 2014 | 12:11 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i don't know, never had an issue even running in 4x4 at triple digit speeds. bigger truck but same idea though. Thank god for aftermarket tuners to remove the limiter.
Old Apr 16, 2014 | 08:07 AM
jch4's Avatar
jch4
85 MPH
I had a 86 f150 w/ the 302 Fuel injection, 3:55 gears and it would only run 85. Mostly due the AOD would not stay in OD and would kick back to 3rd. It sure got to 85 quick thou. My work truck, 85 f250 with the HO 351 would run over 100 all day.
Old Apr 16, 2014 | 08:10 AM
MisterCMK's Avatar
MisterCMK
Since I asked the question and referred to the safety aspect, safety is obviously not reason enough for me. If you don't have an answer why post?
What if that is their only reason for doing so?
Old Apr 16, 2014 | 10:53 AM
BuzzLOL's Avatar
BuzzLOL
. Hey jch4, how about a picture of the speedo and tach on that F250 at over 100 MPH?
Old Apr 16, 2014 | 07:01 PM
paredneck33's Avatar
paredneck33
I have an 86 F150 4x4 with the 302. It's backed by a n.p. 435 4 speed. And I can easily break into triple digits with it. I just would suggest running it there for extended periods or for very often. As these engines weren't built for that purpose. I should mention it runs the 3.50 gear ratio.
Old Apr 16, 2014 | 07:05 PM
paredneck33
If safety and liability aren't enough of a reason for you then what is?
Old Apr 17, 2014 | 08:15 AM
jch4's Avatar
jch4
Sorry Buzz, that was long before cell phone cameras and the like. All I know is it ran very well and would bury the needle.
Old Apr 17, 2014 | 11:28 AM
  #28
BuzzLOL's Avatar
BuzzLOL
. An '85 truck had an 85 MPH speedo that would 'bury' easily?
Old Apr 17, 2014 | 02:21 PM
  #29
jdadamsjr's Avatar
jdadamsjr
Why a limiter?
Common sense that's not too common anymore
I would have no qualms about it if I knew my equipment was up to it and I didn't have to worry about some doofuss doing some thing stupid in front of me !
Old Apr 19, 2014 | 01:12 PM
  #30
Raider50's Avatar
Raider50
I cant run that fast in the quarter but the SC 05 will do at least 120. I don't know how much faster thanks to the spedo. I have the ram air hood but with the inlets blocked off and has never done anything. Now I hit a deer going 80 in a Buick park avenue the hood popped open...It was scarier than hitting the deer.
Get some 10 ply tires and a good custom tune. Get going really fast in your truck...I only had to do it once, didn't care to do it again. Handling was very very sketchy.
