Sponsored by: Auxito
1999 4.6 idle problem
Old Oct 2, 2013 | 02:36 PM
fly'n dutchman's Avatar
fly'n dutchman
Question 1999 4.6 idle problem
Hey guys i have a 1999 f-150 4x4 4.6 5spd manual 180,000 miles on the
clock. My question is, when coming to a stop i push the clutch in an the
idle hangs at about twice what it should be until i come to a complete
stop then it drops to normal. It's not like somethings sticking cause it
will stay at the high idle as long as were rolling but as soon as the wheels
stop turning it drops down, any ideas?
thanks!
Old Oct 2, 2013 | 03:32 PM
Bluegrass 7's Avatar
Bluegrass 7
I've seen this issue reported a number of times across all Ford lines.
Normally when deceleration occurs the IACs closes down to just enough to keep the motor from stalling and turns fuel injection off for the short period of time.
The way the computer knows what to do is by the TPS being near shutdown and the speed sensor output slowing.
The speed sensing is part of a circuit that goes through the clutch pedal switching to the PCM..
You say the idle hangs up when the clutch is depressed suggests the speed circuit is disrupting the normal decell action.
I can't tell you just what to do but this is the way it's supposed to work.
If there is an open or short at some point, the normal action will be upset leaving the IAC open and fuel still on to run the motor at high RPM idle speeds..
Good luck.
Old Oct 2, 2013 | 10:15 PM
fly'n dutchman
46 idle problem
Thanks Bluegrass7, been finding alot of corrosion on the wiring in this truck. This old girl musta been through afew salty PA. winters. I'll start
cleaning connections an watch for a parts truck. Thanks again for the
help.
Motoss
1997 - 2003 F150
Jul 24, 2019 12:47 AM
bheneee
1997 - 2003 F150
Sep 12, 2009 09:57 AM
Joey in IN
1997 - 2003 F150
Dec 8, 2007 07:45 AM
jb'sghost
1997 - 2003 F150
Jun 22, 2003 11:42 PM
Big89
1997 - 2003 F150
Apr 5, 2003 07:03 PM
